Acer Aspire V5-473P-5602 Motherboard Replacement
  1. Acer Aspire V5-473P-5602 Motherboard Replacement, Back Panel: step 1, image 1 of 2 Acer Aspire V5-473P-5602 Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Motherboard Replacement, Battery: step 2, image 1 of 2 Acer Aspire V5-473P-5602 Motherboard Replacement, Battery: step 2, image 2 of 2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Motherboard Replacement: step 3, image 1 of 1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Motherboard Replacement: step 4, image 1 of 1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Motherboard Replacement, Hard Drive: step 5, image 1 of 1
    • Remove the four Phillips #0 screws from the hard drive.
  6. Acer Aspire V5-473P-5602 Motherboard Replacement: step 6, image 1 of 1
    • Gently unplug the hard drive connector.
  7. Acer Aspire V5-473P-5602 Motherboard Replacement: step 7, image 1 of 1
    • Remove the hard drive from the laptop.
  8. Acer Aspire V5-473P-5602 Motherboard Replacement, Fan: step 8, image 1 of 2 Acer Aspire V5-473P-5602 Motherboard Replacement, Fan: step 8, image 2 of 2
    • Remove the five Phillips #0 screws that are holding the fan down to the base.
  9. Acer Aspire V5-473P-5602 Motherboard Replacement: step 9, image 1 of 2 Acer Aspire V5-473P-5602 Motherboard Replacement: step 9, image 2 of 2
    • Gently unplug the cables from the Wi-Fi card.
  10. Acer Aspire V5-473P-5602 Motherboard Replacement: step 10, image 1 of 1
    • Remove the fan from the laptop.
  11. Acer Aspire V5-473P-5602 Motherboard Replacement, Secondary Cooling Fan: step 11, image 1 of 2 Acer Aspire V5-473P-5602 Motherboard Replacement, Secondary Cooling Fan: step 11, image 2 of 2
    • Unplug the cable that connects to the fan to motherboard.
  12. Acer Aspire V5-473P-5602 Motherboard Replacement: step 12, image 1 of 1
    • Remove the two Phillips #0 screws that secure the fan to the base.
  13. Acer Aspire V5-473P-5602 Motherboard Replacement, Motherboard: step 13, image 1 of 2 Acer Aspire V5-473P-5602 Motherboard Replacement, Motherboard: step 13, image 2 of 2
    • Remove the ten Phillips #0 screws that attach the motherboard to the keyboard.
  14. Acer Aspire V5-473P-5602 Motherboard Replacement: step 14, image 1 of 3 Acer Aspire V5-473P-5602 Motherboard Replacement: step 14, image 2 of 3 Acer Aspire V5-473P-5602 Motherboard Replacement: step 14, image 3 of 3
    • Unplug the two data cables that attach the keyboard to the motherboard.
    • Remove the motherboard from the laptop.
Kristen Gismondi
82,236 Reputation
200 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,259 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 33
All Time: 856
