Introduction
In this guide, you will learn how to replace the Wi-Fi card on the Acer Inspire R7 laptop (R7-371T-78GX).
A Wi-Fi card is used to receive wireless signals from your wireless network. Over time the Wi-Fi card can fail or be upgraded for a stronger card. Review the iFixit page on the Acer Aspire R7 for more details on Wi-Fi card issues.
When starting this project, make sure to power off your laptop and unplug from the power adapter. Overlooking this detail can cause damage to hardware.
Remove seven 10 mm T7 screws.
Remove four 6 mm T7 screws.
Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
Remove the remaining four 10 mm T7 screws.
Step 2 is missing the 1 (10mm T-7 ) screw that is under a rubber pad in the bottom middle of the laptop. The picture shows this pad and screw already missing. Note the silver color instead of the black color of the rest of the bottom of the laptop.
Locate the WiFi Card antenna wires
Remove both antenna wires from the WiFi card by prying upwards with the spudger tool
2 other people completed this guide.
2 Comments
This answer might be useful for others who still want to update their Wifi card in their R7-572.
I just replaced the original Broadcom BCM943228HMB on my R7-572 with an Intel 7260HMW CN: 08TF1D (Standard half-height mini PCI-e interface card ). I found it on ebay:https://www.ebay.ca/itm/4-0-Wireless-Min... (19 USD as of October 2018)
After the card is installed, run Intel Driver & Support Assistant and my driver where updated to the latest ones (for both the AC 7260 and the Bluetooth adapter). http://www.intel.com/content/www/us/en/s...
I am using Windows 8.1 on this laptop.
HTH
Use the blue plastic opening tool to carefully remove the rubber pad which covers the one remaining screw.
Picture shows the rubber pad removed but srew to be removed is not indicated
Anthymoine - Reply
