Introduction
This guide will show the reader how to remove the back panel from their Acer Aspire R5-571T-59DC.
Be sure to be gentle opening the inner snaps around the lining of the cover - gently running a credit card or spudger around the inside of the lining should be sufficient to loosen the cover.
This is a prerequisite step to replacing any component connected to the motherboard.
Turn laptop over.
Remove the 07.mm Phillips #0 screws (total of 12 screws) from the back cover of the device.
Using the spudger, gently pry the back cover off of the device. There are several plastic snaps located on the inside of the cover - run the spudger around the perimeter of the cover to open each snap. Once the back cover is fully disconnected from the device, lift the cover off and set aside.
