Introduction
After getting the motherboard, it is rather straight forward to get to the RAM.
Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
There are three tabs located on the top of the keyboard.
Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
As you move to the next tab, ensure the previous tab doesn't reset itself.
Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Remove three 5.8 mm Phillips #0 screws from the bottom of the case
Remove three 3.9 mm Phillips #1 screws from the battery compartment.
Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
Gently lift off the top case.
Disconnect the two antenna cables from the right side of the wireless card.
Remove three 3.9 mm Phillips #1 screws from the small I/O board.
Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
