Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: step 1, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 2, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: step 3, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: step 3, image 2 of 2
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 4, image 1 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 4, image 2 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 4, image 3 of 3
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 5, image 1 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 5, image 2 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 5, image 3 of 3
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  6. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: step 6, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: step 6, image 2 of 2
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  7. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 7, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 7, image 2 of 2
    • Remove the two connectors on the Wifi card by pulling them upwards away from the card.
  8. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 8, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 8, image 2 of 2
    • Remove the black connection cord by tugging away from the slot.
  9. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 9, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 9, image 2 of 2
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  10. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: step 10, image 1 of 1
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
Joseph
685 Reputation
6 Guides authored
USF Tampa, Team S20-G1, Passmore Spring 2018 Member of USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 1,629
