Introduction
The display is the main interaction with the user providing image. This outline will show you how to remove and replace the display from the device.
Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
Remove the four 5mm Phillips #0 screws from the display hinge.
Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
The screen is now completely removed from the bottom half of the computer.
