Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Back Panel: step 1, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 2, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Battery: step 3, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement, Battery: step 3, image 2 of 2
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 4, image 1 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 4, image 2 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 4, image 3 of 3
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 5, image 1 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 5, image 2 of 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Battery Replacement: step 5, image 3 of 3
    • Disconnect the battery from the motherboard.
    • Remove the battery.
Joseph
685 Reputation
6 Guides authored
USF Tampa, Team S20-G1, Passmore Spring 2018 Member of USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,950
