Acer AL2216W Power Supply Capacitor Replacement
  1. Acer AL2216W Power Supply Capacitor Replacement, Discharge the old capacitors: step 1, image 1 of 1
    • Caution: If you are uncertain about holding high voltage parts, follow all provided warnings and use common sense. A capacitor discharge tool is STRONGLY RECOMMENDED.
    • The filter capacitor will hold the most residual charge. Use caution around this capacitor!
    • Unplug the monitor and leave it unplugged for 24-48 hours. Wait 5-7 days if you intend to replace the filter capacitor.
  2. Acer AL2216W Power Supply Capacitor Replacement, Remove the stand: step 2, image 1 of 2 Acer AL2216W Power Supply Capacitor Replacement, Remove the stand: step 2, image 2 of 2
    • This monitor never came with a hinge cap. If yours has one, snap it off from the marked points.
    • Remove the stand from the monitor. Remove the 4 screws that hold the stand on. The bottom screws should be removed first, but this can be done in any order.
  3. Acer AL2216W Power Supply Capacitor Replacement, Remove the back of the monitor: step 3, image 1 of 2 Acer AL2216W Power Supply Capacitor Replacement, Remove the back of the monitor: step 3, image 2 of 2
    • Remove 4 fine threaded screws from the back of the monitor. All of these screws are the same type and length.
    • This screw is unique and only goes in one place as the thread is different. Set it aside separately from the other screws.
  4. Acer AL2216W Power Supply Capacitor Replacement, Unlatch the clips (Bottom): step 4, image 1 of 2 Acer AL2216W Power Supply Capacitor Replacement, Unlatch the clips (Bottom): step 4, image 2 of 2
    • If the monitor has never been serviced, a flathead screwdriver may be needed. This will damage the plastic casing.
    • On the bottom of the monitor, there are four slots to open the monitor. To release these clips, use a Jimmy or flathead screwdriver.
  5. Acer AL2216W Power Supply Capacitor Replacement, Unlatch the clips (Side): step 5, image 1 of 1
    • If you are having trouble doing this, a pry tool can help. This is common on unserviced examples.
    • With the monitor unclipped on the bottom, pull the sides of the monitor up. Do this slowly to avoid damaging the plastics and LCD.
  6. Acer AL2216W Power Supply Capacitor Replacement, Remove the IEC socket screws: step 6, image 1 of 1
    • After these screws are removed, the power supply will be exposed.
    • With the back of the monitor off, remove the 2 screws on the IEC power connector.
  7. Acer AL2216W Power Supply Capacitor Replacement, Remove the video connection screws: step 7, image 1 of 1
    • If you do not have a nut driver on hand, needlenoose plyers can also be used.
    • Remove the 4 screw pins for the video cables from the monitor. Use a 5mm Nut bit/driver to remove the screw pins from the power supply shield.
  8. Acer AL2216W Power Supply Capacitor Replacement, Disconnect the backlight cables: step 8, image 1 of 2 Acer AL2216W Power Supply Capacitor Replacement, Disconnect the backlight cables: step 8, image 2 of 2
    • Disconnect the CCFL cables from the power supply board.
  9. Acer AL2216W Power Supply Capacitor Replacement, Disconnect the button board: step 9, image 1 of 2 Acer AL2216W Power Supply Capacitor Replacement, Disconnect the button board: step 9, image 2 of 2
    • Removal of this board is optional as it is non interfering.
    • Disconnect the flat flex cable that goes to the control board.
  10. Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply shield (Part 1): step 10, image 1 of 2 Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply shield (Part 1): step 10, image 2 of 2
    • Remove the 2 bottom screws that hold the power supply shield to the monitor.
  11. Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply shield (Part 2): step 11, image 1 of 3 Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply shield (Part 2): step 11, image 2 of 3 Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply shield (Part 2): step 11, image 3 of 3
    • On the right side of the monitor, remove the remaining screws holding the upper shield in place.
    • Lift the lower plate up while removing the power supply shield to remove it from the monitor. Once this is done, you will have access to the power supply.
    • Removal of the lower shield is not required but makes the job easier. To remove it, unclip the plastic tabs on the LCD bezel.
  12. Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply: step 12, image 1 of 3 Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply: step 12, image 2 of 3 Acer AL2216W Power Supply Capacitor Replacement, Remove the power supply: step 12, image 3 of 3
    • If you see bulged capacitors, treat the power supply as if the capacitors are holding a residual charge.
    • If the filter capacitor is replaced, it MUST be discharged before removal. In addition, the black screw (Blue marker) is a grounding screw and cannot be lost.
    • Only lift the power supply board at a slight angle. Lifting it any higher may damage the processing board or interface.
    • If you cannot find the original capacitors, the original parts can be safely substituted.
    • This capacitor is only used on older revisions. If your board has this capacitor, it should be replaced if handy.
    • With the power supply shield removed from the monitor, identify the power supply. Along with the listed capacitors, take note of any others you want to replace (Ex: Inverter coil).
    • Remove the 4 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis mounting holes.
  13. Acer AL2216W Power Supply Capacitor Replacement, (Optional) Capacitor polarity marking: step 13, image 1 of 1
    • If the PCB is marked to avoid mis-installation, these marks will come off when soldered in place.
    • If you are unsure of the position of the capacitors, mark the polarity with a permanent marker. If the capacitors are installed incorrectly, they will explode when power is applied.
  14. Acer AL2216W Power Supply Capacitor Replacement, Add flux to the capacitor leads: step 14, image 1 of 1
    • If you do not have flux on hand, solder can be used. The flux will be more difficult to clean if too much is used.
    • To prepare the board for capacitor replacement, add flux or solder to ease removal.
  15. Acer AL2216W Power Supply Capacitor Replacement, Remove the old capacitors: step 15, image 1 of 3 Acer AL2216W Power Supply Capacitor Replacement, Remove the old capacitors: step 15, image 2 of 3 Acer AL2216W Power Supply Capacitor Replacement, Remove the old capacitors: step 15, image 3 of 3
    • If you do not have Helping Hands, be careful not to touch your soldering iron. The board can be held at an angle if this is easier.
    • While it may be possible to do a partial replacement, the remaining capacitors will fail. Do it once and change the entire set. Refer to this guide for soldering tips: How To Solder and Desolder Connections.
    • Move in a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat up the leg to remove it from the board.
    • After removing the capacitors, clean up the old solder with a desoldering braid Lift it with the iron when removing it.
  16. Acer AL2216W Power Supply Capacitor Replacement, Installing brand new capacitors: step 16, image 1 of 1
    • Check the capacitor polarity before soldering the new capacitors in. If they are installed incorrectly, they will explode!
    • Install the new capacitors. Check the polarity/placement and bend the leads so they do not come loose during installation.
  17. Acer AL2216W Power Supply Capacitor Replacement, Solder the new capacitors in: step 17, image 1 of 3 Acer AL2216W Power Supply Capacitor Replacement, Solder the new capacitors in: step 17, image 2 of 3 Acer AL2216W Power Supply Capacitor Replacement, Solder the new capacitors in: step 17, image 3 of 3
    • Once the polarity is verified, solder the capacitors in. After installation, cut off any excess lead.
  18. Acer AL2216W Power Supply Capacitor Replacement, Clean the flux off of the board: step 18, image 1 of 1
    • After verifying there are no cold solder joints, clean the board. This can be cleaned with 91%+ Isopropyl or Denatured alcohol.
  19. Acer AL2216W Power Supply Capacitor Replacement, Test the monitor: step 19, image 1 of 1
    • Put the monitor back together and test it with a signal. If the repair worked, you will have a visible image.
Nick
88,911 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,540 Guides authored
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 77
All Time: 22,409
