Abask A8 Photodiode Replacement
    1. Abask A8 Photodiode Replacement, Internal Assembly: step 1, image 1 of 3 Abask A8 Photodiode Replacement, Internal Assembly: step 1, image 2 of 3 Abask A8 Photodiode Replacement, Internal Assembly: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws on the front plate.
      • Gently insert a pry between the front panel and the main body, working around the edges to pop it off.
      • Pull the main body from the shell.
      • Be careful not to damage the ribbon cable, as they are very fragile. Ribbon cables look like thin pieces of silver duct-tape.
      Ask FixBot
    2. Abask A8 Photodiode Replacement: step 2, image 1 of 2 Abask A8 Photodiode Replacement: step 2, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws that secure the screen.
      Ask FixBot
    3. Abask A8 Photodiode Replacement: step 3, image 1 of 3 Abask A8 Photodiode Replacement: step 3, image 2 of 3 Abask A8 Photodiode Replacement: step 3, image 3 of 3
      • Remove the internal facing camera with care not to strain the connected ribbon cable.
      • Lift up the black ZIF locking flap and disconnect the ribbon cable.
      Ask FixBot
    4. Abask A8 Photodiode Replacement: step 4, image 1 of 3 Abask A8 Photodiode Replacement: step 4, image 2 of 3 Abask A8 Photodiode Replacement: step 4, image 3 of 3
      • Lift the camera connector ZIF locking flap.
      • Gently remove the ribbon cable from the connector and fully remove the camera.
      Ask FixBot
    5. Abask A8 Photodiode Replacement: step 5, image 1 of 2 Abask A8 Photodiode Replacement: step 5, image 2 of 2
      • Using a Jimmy prying tool, lift the supercapacitor out of its slot.
      • Be careful not to puncture the supercapacitor.
      Ask FixBot
    1. Abask A8 Photodiode Replacement, Motherboard: step 6, image 1 of 2 Abask A8 Photodiode Replacement, Motherboard: step 6, image 2 of 2
      • Lift the ZIF locking flap that is securing the ribbon cable connecting the motherboard to the shell.
      Ask FixBot
    2. Abask A8 Photodiode Replacement: step 7, image 1 of 2 Abask A8 Photodiode Replacement: step 7, image 2 of 2
      • Gently lift the ribbon cable locking flap and disconnect the ribbon cable from the motherboard.
      • Carefully separate the motherboard from the screen.
      Ask FixBot
    1. Abask A8 Photodiode Replacement, Photodiode: step 8, image 1 of 1
      • Gently release the silver locking flap that is holding the ribbon cable connecting the photodiode to the motherboard.
      • Carefully pull the flat ribbon cable out of the connector.
      Ask FixBot
    2. Abask A8 Photodiode Replacement: step 9, image 1 of 2 Abask A8 Photodiode Replacement: step 9, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the four 1.6 mm screws that secure the photodiode.
      • Carefully lift the old photodiode out of its base.
      • To avoid damaging the photodiode, make sure to place it face down on a clean, static-free surface when not handling it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Lindsey Fennell
341 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 51
All Time: 286
