ATT CL4940 Internal Microphone Replacement
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: step 1, image 1 of 2 ATT CL4940 Internal Microphone Replacement, Internal Microphone: step 1, image 2 of 2
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: step 2, image 1 of 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: step 3, image 1 of 3 ATT CL4940 Internal Microphone Replacement: step 3, image 2 of 3 ATT CL4940 Internal Microphone Replacement: step 3, image 3 of 3
    • Starting from the bottom of the device, using a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: step 4, image 1 of 1
    • Using wire cutters, sever both the red and black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling.
Charles Moore
201 Reputation
2 Guides authored
IUPUI, Team 2-2, Harley Spring 2016 Member of IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 28
All Time: 615
