ASUS X44H-BBR4 Hard Drive Replacement
  1. ASUS X44H-BBR4 Hard Drive Replacement, Battery: step 1, image 1 of 2 ASUS X44H-BBR4 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Flip the device over.
  2. ASUS X44H-BBR4 Hard Drive Replacement: step 2, image 1 of 3 ASUS X44H-BBR4 Hard Drive Replacement: step 2, image 2 of 3 ASUS X44H-BBR4 Hard Drive Replacement: step 2, image 3 of 3
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 Hard Drive Replacement: step 3, image 1 of 2 ASUS X44H-BBR4 Hard Drive Replacement: step 3, image 2 of 2
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 Hard Drive Replacement: step 4, image 1 of 3 ASUS X44H-BBR4 Hard Drive Replacement: step 4, image 2 of 3 ASUS X44H-BBR4 Hard Drive Replacement: step 4, image 3 of 3
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: step 5, image 1 of 2 ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: step 5, image 2 of 2
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  6. ASUS X44H-BBR4 Hard Drive Replacement: step 6, image 1 of 2 ASUS X44H-BBR4 Hard Drive Replacement: step 6, image 2 of 2
    • Once the screws are removed, slide the back panel away from the computer.
  7. ASUS X44H-BBR4 Hard Drive Replacement: step 7, image 1 of 1
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  8. ASUS X44H-BBR4 Hard Drive Replacement: step 8, image 1 of 2 ASUS X44H-BBR4 Hard Drive Replacement: step 8, image 2 of 2
    • Slide the hard drive to the left, unlocking it from its default position.
  9. ASUS X44H-BBR4 Hard Drive Replacement: step 9, image 1 of 2 ASUS X44H-BBR4 Hard Drive Replacement: step 9, image 2 of 2
    • Pull the hard drive upwards and take it out of its position.
  10. ASUS X44H-BBR4 Hard Drive Replacement: step 10, image 1 of 3 ASUS X44H-BBR4 Hard Drive Replacement: step 10, image 2 of 3 ASUS X44H-BBR4 Hard Drive Replacement: step 10, image 3 of 3
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  11. ASUS X44H-BBR4 Hard Drive Replacement: step 11, image 1 of 1
    • Pull upwards on the metal casing and it will come off.
Devaj Ramsamooj
824 Reputation
5 Guides authored
UMass Dartmouth, Team 4-3, Catania Fall 2015 Member of UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 1,216
