Introduction
Use this guide to help you replace the Hard Drive. Don't forget to keep track of your screws.
Slide the right lock button to the unlock position.
After it is unlocked, a red line will be visible.
While holding the left lock button in the unlock position, push the battery from the center away from you.
Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
