Introduction
Recently i bought a new device ASUS All-In-One V241 and it has very slow HDD Toshiba and 4Gb RAM DDR4.
This is my first replacement guide - i hope it will be helpful for you :)
Power off your device
Place it horizontaly on the stable ground
Remove 4 screws at the bottom of the display
Take grey panel from the sides and pull it up
After disconnecting two connectors from the motherboard you can lift display up
Now you can see motherboard, covered up by metal cover
HDD - on the left side. Remove screws and pull HDD-case
Remove screws from the metal cover and pull up - you can see the motherboard
RAM - 2 Slots, DDR4 2400 Mhz
