ASUS Vivo AiO V241IC HDD and RAM Replacement
  1. ASUS Vivo AiO V241IC HDD and RAM Replacement, Remove 4 screws: step 1, image 1 of 1
    • Power off your device
    • Place it horizontaly on the stable ground
    • Remove 4 screws at the bottom of the display
    • Take grey panel from the sides and pull it up
    • Be careful to pulling up - there are two connectors, which goes from display to motherboard. You can safelly lift display for 5-7 cm (like on the photo)
  2. ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: step 2, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: step 2, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, Lift up display: step 2, image 3 of 3
    • After disconnecting two connectors from the motherboard you can lift display up
    • There is an also connector to display from motherboard and do not hurry to lift up display
    • There is no metal cover from the motherboard on this photo
  3. ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: step 3, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: step 3, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, HDD: step 3, image 3 of 3
    • Now you can see motherboard, covered up by metal cover
    • HDD - on the left side. Remove screws and pull HDD-case
  4. ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: step 4, image 1 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: step 4, image 2 of 3 ASUS Vivo AiO V241IC HDD and RAM Replacement, RAM: step 4, image 3 of 3
    • Remove screws from the metal cover and pull up - you can see the motherboard
    • RAM - 2 Slots, DDR4 2400 Mhz
Konstantin Epikhin
471 Reputation
1 Guide authored
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 171
All Time: 22,936
