ASUS Q536F Screen Replacement
  1. ASUS Q536F Screen Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F Screen Replacement, Back Panel: step 1, image 2 of 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Screen Replacement, Display Assembly: step 2, image 1 of 1
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
  3. ASUS Q536F Screen Replacement: step 3, image 1 of 3 ASUS Q536F Screen Replacement: step 3, image 2 of 3 ASUS Q536F Screen Replacement: step 3, image 3 of 3
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
  4. ASUS Q536F Screen Replacement, Screen: step 4, image 1 of 3 ASUS Q536F Screen Replacement, Screen: step 4, image 2 of 3 ASUS Q536F Screen Replacement, Screen: step 4, image 3 of 3
    • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
    • Use an iOpener to help loosen the adhesive on the screen.
    • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
    • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
  5. ASUS Q536F Screen Replacement: step 5, image 1 of 1
    • Carefully remove the screen from the rest of the display.
    • The new screen should come with the sticky adhesive.
Adra Ledward
557 Reputation
5 Guides authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
6 Guides authored
1 Guide Comment
I've never had to do a screen replacement but I know my way around PCs. Laptops not as much, but have done other smaller repairs. Replacing the entire screen has me quite anxious. Whats the difficulty level on that?
Acrillix Official - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 569
