Introduction
This guide will show you how to remove the gearbox from a 250cc AJS Model 14 / Matchless G2 or a 350cc AJS Model 8 / Matchless G5 motorcycle (all years).
You will need a set of Whitworth spanners or sockets and a decent flat-bladed screwdriver.
Note that the bike featured in this guide has a few modifications from standard, so your bike may look a little different in places. The basic technique remains the same, regardless of which model of Lightweight you have.
Remove the six screws holding the primary drive cover on.
Lift the cover away. Note that the cables to the alternator will still be attached, so make sure the cover is supported and not pulling on the cables.
Unscrew the clutch springs with a piece of flat metal.
Lift off the clutch cover and withdraw the clutch operating rod and clutch plates.
Engage a gear and undo the clutch retaining nut. This is likely to be tight; it will undo more easily if you "shock" it loose with light hammer taps onto a socket driver.
Remove the kickstart.
Remove the gear position indicator (if fitted) and the gear lever.
Remove the exhaust.
Remove the link from the rear chain and move it clear of the gearbox sprocket.
Drain the oil from the gearbox.
Undo the four screws holding the right side cover on and remove it.
Undo the two screws holding the inspection cover on and remove it.
Slacken off the clutch cable completely at the handlebar end and release it from the clutch lever.
Push the cable through to release it at the gearbox end.
Look in through the gearbox inspection hole and release the cable from the operating fork.
Withdraw the clutch cable from the gearbox and put it to one side.
Remove the two barrel bolts from the gearbox retaining bands.
Remove the two nuts holding the tensioner in place.
Withdraw the tensioner and the two spacers either side of the gearbox mounting tab.
Remove the two nuts at the rear of the mounting plate.
Lift the mounting plate away.
