AJS/Matchless Lightweight Gearbox Removal
  1. AJS/Matchless Lightweight Gearbox Removal, Remove the primary drive cover: step 1, image 1 of 2 AJS/Matchless Lightweight Gearbox Removal, Remove the primary drive cover: step 1, image 2 of 2
    • Remove the six screws holding the primary drive cover on.
    • You can either drain the oil first, or just put a dish underneath to catch the oil spillage.
    • Lift the cover away. Note that the cables to the alternator will still be attached, so make sure the cover is supported and not pulling on the cables.
  2. AJS/Matchless Lightweight Gearbox Removal, Undo the clutch: step 2, image 1 of 3 AJS/Matchless Lightweight Gearbox Removal, Undo the clutch: step 2, image 2 of 3 AJS/Matchless Lightweight Gearbox Removal, Undo the clutch: step 2, image 3 of 3
    • Unscrew the clutch springs with a piece of flat metal.
    • Lift off the clutch cover and withdraw the clutch operating rod and clutch plates.
    • Engage a gear and undo the clutch retaining nut. This is likely to be tight; it will undo more easily if you "shock" it loose with light hammer taps onto a socket driver.
    • If you are lucky, the clutch will be loose on the shaft. If it is stuck fast, you may need to use the special puller.
  3. AJS/Matchless Lightweight Gearbox Removal, Remove ancillaries: step 3, image 1 of 3 AJS/Matchless Lightweight Gearbox Removal, Remove ancillaries: step 3, image 2 of 3 AJS/Matchless Lightweight Gearbox Removal, Remove ancillaries: step 3, image 3 of 3
    • Remove the kickstart.
    • Remove the gear position indicator (if fitted) and the gear lever.
    • Remove the exhaust.
    • You may need to remove other ancillaries such as footrests and chain cover (not shown in these pictures)
    • Remove the link from the rear chain and move it clear of the gearbox sprocket.
    • Drain the oil from the gearbox.
  4. AJS/Matchless Lightweight Gearbox Removal, Right side cover: step 4, image 1 of 2 AJS/Matchless Lightweight Gearbox Removal, Right side cover: step 4, image 2 of 2
    • Undo the four screws holding the right side cover on and remove it.
    • Some trapped oil may run out if there are any leaks on this side of the engine.
    • Undo the two screws holding the inspection cover on and remove it.
  5. AJS/Matchless Lightweight Gearbox Removal, Release the clutch cable: step 5, image 1 of 2 AJS/Matchless Lightweight Gearbox Removal, Release the clutch cable: step 5, image 2 of 2
    • Slacken off the clutch cable completely at the handlebar end and release it from the clutch lever.
    • Push the cable through to release it at the gearbox end.
    • Look in through the gearbox inspection hole and release the cable from the operating fork.
    • Withdraw the clutch cable from the gearbox and put it to one side.
  6. AJS/Matchless Lightweight Gearbox Removal, Remove gearbox tensioner: step 6, image 1 of 3 AJS/Matchless Lightweight Gearbox Removal, Remove gearbox tensioner: step 6, image 2 of 3 AJS/Matchless Lightweight Gearbox Removal, Remove gearbox tensioner: step 6, image 3 of 3
    • Remove the two barrel bolts from the gearbox retaining bands.
    • Remove the two nuts holding the tensioner in place.
    • Withdraw the tensioner and the two spacers either side of the gearbox mounting tab.
  7. AJS/Matchless Lightweight Gearbox Removal, Remove gearbox mounting plate: step 7, image 1 of 2 AJS/Matchless Lightweight Gearbox Removal, Remove gearbox mounting plate: step 7, image 2 of 2
    • Remove the two nuts at the rear of the mounting plate.
    • Lift the mounting plate away.
  8. AJS/Matchless Lightweight Gearbox Removal, Remove the gearbox: step 8, image 1 of 1
    • You can now lift the gearbox away from the bike.
    • Don't forget to hold on to the clutch basket on the other side of the bike. It will fall away as you remove the gearbox.
Paul Barnfather
1,004 Reputation
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 19
All Time: 2,322
