8BitDo Ultimate Wireless Button Conductive Pad Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
58
Past 30 Days:
172
All Time:
774
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The button conductive pad is a silicon component located beneath each button (including the D-pad). It allows the button to interface with a conductive contact on the control board, registering an input when pressed. Over time, these pads can accumulate dirt, dust, oils, and wear down, leading to unresponsive and overall less consistent inputs. Accessing these pads and cleaning/replacing them can potentially resolve these problems.
Tools
    1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: step 1, image 1 of 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: step 1, image 2 of 2
      • Insert an opening pick into the seam between the left controller grip and main controller body.
      • Pry the grip off.
      • Repeat for the right grip.
      Ask FixBot
    2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 2, image 1 of 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 2, image 2 of 2
      • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
      Ask FixBot
    3. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 3, image 1 of 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 3, image 2 of 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 3, image 3 of 3
      • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
      • Set the halves next to each other with care not to strain the connected ribbon cables.
      Ask FixBot
    4. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 4, image 1 of 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 4, image 2 of 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 4, image 3 of 3
      • The ribbon cable is secured with a locking tab connector.
      • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
      Ask FixBot
    1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: step 5, image 1 of 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: step 5, image 2 of 2
      • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell.
      • Lift the PCB out.
      Ask FixBot
    2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 6, image 1 of 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement: step 6, image 2 of 2
      • Lift button conductive pads out of the shell with your hands.
      • Replace or clean as needed.
      • If cleaning with water, make sure pads are fully dry before replacing.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
John Sweriduk
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 58
Past 30 Days: 172
All Time: 774
