Introduction
Go to step 1 ↓Do you need to replace the battery for your 8BitDo Ultimate Wireless? If so, this guide will show you how to correctly and safely do so!
With that said, please make sure to check our Troubleshooting Guides first. Often times, there is no need to go as far to make a battery replacement.
Before beginning, turn off the controller and ideally make sure that it won't accidentally reconnect.
Tools
Safety Glasses4.9
High Content Rubbing Alcohol$12.99
Spudger4.9
Insert an opening pick into the seam between the left controller grip and main controller body.
Pry the grip off.
Repeat for the right grip.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
