8BitDo Pro 2 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
45
Past 30 Days:
238
All Time:
967
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your 8BitDol Pro 2 controller is not turning on, losing charge quickly, or not holding a charge at all, the battery pack may need to be replaced. Over time, rechargeable batteries can wear down and lose their ability to function the correct way.
This guide will walk you through removing and replacing the battery pack. This is a simple and quick repair that requires no tools.
Before you begin, make sure that the controller is powered off.
    1. 8BitDo Pro 2 Battery Replacement, Battery: step 1, image 1 of 1
      • Flip the 8BitDo Pro 2 controller so that the back side is facing up.
      Ask FixBot
    2. 8BitDo Pro 2 Battery Replacement: step 2, image 1 of 1
      • Slide the battery cover off to remove it and expose the battery.
      Ask FixBot
    3. 8BitDo Pro 2 Battery Replacement: step 3, image 1 of 1
      • Use your hands to remove the battery pack from the controller.
      • Do not bend or puncture the battery pack, this can be hazardous.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Paige Lucas
643 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 45
Past 30 Days: 238
All Time: 967
