8BitDo Pro 2 Action Button Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
178
All Time:
597
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your 8BitDo Pro 2 controller action buttons are unresponsive or not registering input correctly, the buttons may need to be replaced. This guide will walk you through removing and installing the action buttons on your controller.
The action buttons are responsible for sending the primary input commands during gameplay. Over time, the responsiveness and accuracy can affect the buttons.
Before using this guide, try cleaning around the base of the action buttons, as debris can sometimes interfere with proper function. You should also test the controller on multiple devices to ensure it is in the correct input mode to confirm the issue is hardware related, see the troubleshooting page for more information.
This repair will require you to open the controller. Before beginning, make sure to power off your controller.
Tools
    1. 8BitDo Pro 2 Action Button Replacement, Battery: step 1, image 1 of 1
      • Flip the 8BitDo Pro 2 controller so that the back side is facing up.
      Ask FixBot
    2. 8BitDo Pro 2 Action Button Replacement: step 2, image 1 of 1
      • Slide the battery cover off to remove it and expose the battery.
      Ask FixBot
    3. 8BitDo Pro 2 Action Button Replacement: step 3, image 1 of 1
      • Use your hands to remove the battery pack from the controller.
      • Do not bend or puncture the battery pack, this can be hazardous.
      Ask FixBot
    1. 8BitDo Pro 2 Action Button Replacement, Controller: step 4, image 1 of 1
      • Using the iFixit blunt tweezers, peel back the top two corners of the sticker located inside the battery compartment.
      Ask FixBot
    2. 8BitDo Pro 2 Action Button Replacement: step 5, image 1 of 1
      • Use a T6 Torx screwdriver to remove the four 5.0 mm screws from the back of the controller.
      Ask FixBot
    3. 8BitDo Pro 2 Action Button Replacement: step 6, image 1 of 3 8BitDo Pro 2 Action Button Replacement: step 6, image 2 of 3 8BitDo Pro 2 Action Button Replacement: step 6, image 3 of 3
      • Insert the iFixit pick into the seam along the edge of the controller and slide it around to release the clips holding it together.
      • Leave opening picks in the space to keep the top and bottom case from reattaching.
      • Use an iFixit tool to carefully pry around the edges of the controller.
      • Once loosened, gently separate the top and bottom of the controller.
      • Do not separate the top and bottom sections, as they are still connected by a ribbon cable.
      Ask FixBot
    4. 8BitDo Pro 2 Action Button Replacement: step 7, image 1 of 2 8BitDo Pro 2 Action Button Replacement: step 7, image 2 of 2
      • Use a spudger to gently push up on alternating sides of the black plastic tab until it clicks up into its unlocked position.
      • Don't push the tab too hard or too far, otherwise it may come completely off the connector.
      • Use tweezers to gently pull the cable out of its socket.
      • The cable should be able to slide in and out of the socket with little to no force. If you feel resistance, the tab may not be fully unlocked.
      • During reassembly, insert the cable into its socket and use the flat end of a spudger to push the tab down into its locked position.
      • Separate the top and bottom casing of the controller.
      • If you feel resistance, check for any cables still connecting the two halves and avoid forcing them apart.
      Ask FixBot
    1. 8BitDo Pro 2 Action Button Replacement, Action Button: step 8, image 1 of 3 8BitDo Pro 2 Action Button Replacement, Action Button: step 8, image 2 of 3 8BitDo Pro 2 Action Button Replacement, Action Button: step 8, image 3 of 3
      • Remove the six, 10.0 mm Phillips #00 screws along the edge of the main board.
      • Remove the 5.0 mm Phillips #00 screw towards the center of the board.
      • Pull the motherboard from the top case to remove it.
      Ask FixBot
    2. 8BitDo Pro 2 Action Button Replacement: step 9, image 1 of 1
      • Gently pull the conductive rubber cover from the action buttons.
      Ask FixBot
    3. 8BitDo Pro 2 Action Button Replacement: step 10, image 1 of 1
      • Push the action buttons out of the top case to remove them.
      • You may hear a clicking sound as the action buttons are removed.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Paige Lucas
643 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 178
All Time: 597
