Introduction
This page will guide you on the replacement of the battery on your 360fly 4K camera.
Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
2 other people completed this guide.
4 Comments
Wich one battery Can I use to replace It?
Where can i purchase a battery
I would like to purchase a 360 fly battery
