Introduction
Replacing your oil can be a rewarding and enjoyable process. With the necessary tools and parts anyone can conduct an oil change in their driveway.
Unscrew the oil drain plug with the 17mm wrench. This is located under the front of the car in the gap in the bottom panel.
Adjust the placement of the oil pan if necessary.
Allow the oil to completely drain into the oil pan.
After letting the oil drain for 10 minutes unscrew and remove the oil filter. This is located to the right of the engine when the hood is opened.
Place the old oil filter in the oil filter disposal bag.
Coat the o-ring of the new filter with oil to ensure a good seal.
Screw the new filter into place.
Unscrew cap for engine oil. This is located directly to the left of the oil filter.
Place a clean funnel in the tube.
Slowly fill with the 5.1 quarts of engine oil.
Screw the engine oil cap back on.
Pour the oil from the pan into the empty milk jug.
Your local waste disposal company will recycle this for you.
Allow the car to run for 10 minutes in idle.
Check the oil level with the dipstick. This is located to the right of the engine when the hood is opened.
Check under the car for any dripping liquids.
You have completed an oil and filter change on your 2015 Subaru Forester.
