2012-2016 Subaru Forester Oil and Oil Filter Replacement
  1. 2012-2016 Subaru Forester Oil and Oil Filter Replacement, Oil and Oil Filter: step 1, image 1 of 1
    • Park your car on a level surface.
    • Make sure to put the car in park (first gear for manual transmissions) with the emergency break engaged.
    • Do not change oil within 2 hours of driving the car to allow the oil time to cool.
  2. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 2, image 1 of 1
    • Place the oil pan under the oil drain plug. (this is located under the front end of the car)
    • You may choose to protect the ground with a tarp or piece of cardboard.
  3. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 3, image 1 of 2 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 3, image 2 of 2
    • Unscrew the oil drain plug with the 17mm wrench. This is located under the front of the car in the gap in the bottom panel.
    • Adjust the placement of the oil pan if necessary.
    • Allow the oil to completely drain into the oil pan.
    • Wear clothes that you would not mind getting oil on.
  4. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 4, image 1 of 2 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 4, image 2 of 2
    • After letting the oil drain for 10 minutes unscrew and remove the oil filter. This is located to the right of the engine when the hood is opened.
    • Place the old oil filter in the oil filter disposal bag.
  5. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 5, image 1 of 3 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 5, image 2 of 3 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 5, image 3 of 3
    • Coat the o-ring of the new filter with oil to ensure a good seal.
    • Screw the new filter into place.
  6. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 6, image 1 of 3 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 6, image 2 of 3 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 6, image 3 of 3
    • When reinstalling the oil drain plug, replace the crush washer (part# 803916010) .
    • Tighten the oil drain plug to 32 ft/lbs of torque.
  7. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 7, image 1 of 2 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 7, image 2 of 2
    • Unscrew cap for engine oil. This is located directly to the left of the oil filter.
    • Place a clean funnel in the tube.
    • Slowly fill with the 5.1 quarts of engine oil.
    • Screw the engine oil cap back on.
  8. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 8, image 1 of 1
    • Pour the oil from the pan into the empty milk jug.
    • Your local waste disposal company will recycle this for you.
  9. 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 9, image 1 of 3 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 9, image 2 of 3 2012-2016 Subaru Forester Oil and Oil Filter Replacement: step 9, image 3 of 3
    • Allow the car to run for 10 minutes in idle.
    • Check the oil level with the dipstick. This is located to the right of the engine when the hood is opened.
    • Check under the car for any dripping liquids.
    • You have completed an oil and filter change on your 2015 Subaru Forester.
Matt Lee
590 Reputation
1 Guide authored
Cal Poly, Team 14-2, Green Fall 2015 Member of Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 Members
8 Guides authored
Past 24 Hours: 6
Past 7 Days: 78
Past 30 Days: 431
All Time: 93,174
