2003-2007 Honda Accord Engine Air Filter Replacement
  1. 2003-2007 Honda Accord Engine Air Filter Replacement, Opening the Hood: step 1, image 1 of 2 2003-2007 Honda Accord Engine Air Filter Replacement, Opening the Hood: step 1, image 2 of 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
  2. 2003-2007 Honda Accord Engine Air Filter Replacement: step 2, image 1 of 2 2003-2007 Honda Accord Engine Air Filter Replacement: step 2, image 2 of 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. 2003-2007 Honda Accord Engine Air Filter Replacement: step 3, image 1 of 2 2003-2007 Honda Accord Engine Air Filter Replacement: step 3, image 2 of 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
  4. 2003-2007 Honda Accord Engine Air Filter Replacement, Engine Air Filter: step 4, image 1 of 3 2003-2007 Honda Accord Engine Air Filter Replacement, Engine Air Filter: step 4, image 2 of 3 2003-2007 Honda Accord Engine Air Filter Replacement, Engine Air Filter: step 4, image 3 of 3
    • Be sure your engine is turned off.
    • Identify the engine's air duct hose.
    • The emission hose is located on the top.
    • Remove the emission hose by gently wiggling it out of place.
  5. 2003-2007 Honda Accord Engine Air Filter Replacement: step 5, image 1 of 2 2003-2007 Honda Accord Engine Air Filter Replacement: step 5, image 2 of 2
    • Remove the smog hose by squeezing the tubing and pulling it off.
  6. 2003-2007 Honda Accord Engine Air Filter Replacement: step 6, image 1 of 1
    • Using a Phillips screwdriver, loosen air duct clamp screws.
  7. 2003-2007 Honda Accord Engine Air Filter Replacement: step 7, image 1 of 2 2003-2007 Honda Accord Engine Air Filter Replacement: step 7, image 2 of 2
    • Once the screws are loose, completely remove the air duct hose by gently wiggling it off the engine and the air filter housing.
  8. 2003-2007 Honda Accord Engine Air Filter Replacement: step 8, image 1 of 3 2003-2007 Honda Accord Engine Air Filter Replacement: step 8, image 2 of 3 2003-2007 Honda Accord Engine Air Filter Replacement: step 8, image 3 of 3
    • Remove the air filter housing cap.
    • Using a long Phillips screwdriver or a long 5/16 Hex driver, remove the four screws holding down the air filter housing cap.
  9. 2003-2007 Honda Accord Engine Air Filter Replacement: step 9, image 1 of 1
    • Lift the engine air filter housing cap and place it aside.
    • Do not turn the housing cap upside down. Screws left in holes of housing cap might fall out.
  10. 2003-2007 Honda Accord Engine Air Filter Replacement: step 10, image 1 of 1
    • Lift the dirty filter out of the housing.
    • Vacuum any dirt or debris out of the air filter box.
  11. 2003-2007 Honda Accord Engine Air Filter Replacement, Filter replacement: step 11, image 1 of 1
    • Replace the old filter with the new filter.
    • Ensure that it seats properly in the lip of the air cleaner box.
    • Screw down the air filter housing cap. Connect air dust, emission, and smog hoses.
Shaun MacDonald
2,558 Reputation
8 Guides authored
Cal Poly, Team 24-27, Regan Fall 2012 Member of Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Members
22 Guides authored
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 157
All Time: 33,353
