Introduction
Replace the engine's air filter every 15,000 miles.
Locate the hood latch beside the driver's side door, next to the left foot rest.
Pull the latch toward you to release the hood.
Walk around to the front of the vehicle.
Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
Once the tab is released, lift the hood up.
Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
Place the tip of the hood stand into the hole located in the upper left of the hood.
You can now let the hood rest on the stand.
Identify the engine's air duct hose.
Remove the emission hose by gently wiggling it out of place.
Once the screws are loose, completely remove the air duct hose by gently wiggling it off the engine and the air filter housing.
Remove the air filter housing cap.
Using a long Phillips screwdriver or a long 5/16 Hex driver, remove the four screws holding down the air filter housing cap.
Lift the dirty filter out of the housing.
Vacuum any dirt or debris out of the air filter box.
Replace the old filter with the new filter.
Screw down the air filter housing cap. Connect air dust, emission, and smog hoses.
