Shop the Holiday Gift Guide
08. LCD screen and PSU
View statistics:
Past 24 Hours:
3
Past 7 Days:
41
Past 30 Days:
41
All Time:
41
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
    1. 08. LCD screen and PSU, LCD preparation: step 1, image 1 of 3 08. LCD screen and PSU, LCD preparation: step 1, image 2 of 3 08. LCD screen and PSU, LCD preparation: step 1, image 3 of 3
      • Slide the lcd_support_a and lcd_support_b onto the LCD control board.
      • Verify that the orientation is correct.
      • Assemble the LCD cover on the LCD control board.
      • Adjust the position of the lcd_support_a and lcd_support_b in order to insert the LCD control board on the cover.
      • The LCD control board must clip into the LCD cover.
      • Secure the LCD control board with 2x M3x10 screws (reused from your Original Prusa).
      • Put the LCD knob back in place.
      Ask FixBot
    2. 08. LCD screen and PSU, LCD installation: step 2, image 1 of 2 08. LCD screen and PSU, LCD installation: step 2, image 2 of 2
      • Slide 2x t-nuts in the bottom front of your frame.
      • Attach the LCD using 2x M5x10 screws.
      Ask FixBot
    3. 08. LCD screen and PSU, PSU upper mount preparation: step 3, image 1 of 3 08. LCD screen and PSU, PSU upper mount preparation: step 3, image 2 of 3 08. LCD screen and PSU, PSU upper mount preparation: step 3, image 3 of 3
      • We are going to test your dexterity in this step :)
      • Prepare the following hardware:
      • 2x M4x10 screws (reused from your Original Prusa).
      • 2x psu_upper_mount.
      • Place the M4x10 screw in the internal hole of the psu_upper_mount.
      • If you struggle with this, you can insert a finger in the biggest hole (check the 3rd image). doing this makes it easier for you to hold and guide the screw into the hole.
      • Insert the other M4x10 in the remaining psu_upper_mount.
      • Now try not to lose the screws until we are bolting them on the PSU :D
      Ask FixBot
    4. 08. LCD screen and PSU, PSU type: step 4, image 1 of 2 08. LCD screen and PSU, PSU type: step 4, image 2 of 2
      • The next steps are for the Prusa silver PSU only.
      • If you have the Prusa black PSU, go to step 11
      • If you don't know which PSU you have, please check the second image.
      • Prusa black PSU
      • Prusa silver PSU
      • Image copyright: Prusa Research
      Ask FixBot
    5. 08. LCD screen and PSU, PSU upper mount assembly - Silver PSU: step 5, image 1 of 2 08. LCD screen and PSU, PSU upper mount assembly - Silver PSU: step 5, image 2 of 2
      • Attach the psu_upper_mounts to the silver PSU body. Fully tighten the M4 screws, ensuring that the PSU mounts are properly positioned and aligned .
      • Verify that the psu_upper_mounts are aligned with the PSU
      Ask FixBot
    6. 08. LCD screen and PSU, PSU lower mount assembly - Silver PSU: step 6, image 1 of 3 08. LCD screen and PSU, PSU lower mount assembly - Silver PSU: step 6, image 2 of 3 08. LCD screen and PSU, PSU lower mount assembly - Silver PSU: step 6, image 3 of 3
      • The psu_lower_mount in this step is slightly different for MK2(S)/MK2.5(S) and MK3(S) but they have the same functionality and assembly.
      • Take the psu_lower_mount and insert a square nut.
      • Slide 1x t-nut into the lower channel of the rear extrusion, from the right side of the frame.
      • Assemble the psu_lower_mount with 1x M5x10 screw. Don't tighten fully yet as it will need some repositioning.
      Ask FixBot
    7. 08. LCD screen and PSU, PSU installation - Silver PSU: step 7, image 1 of 3 08. LCD screen and PSU, PSU installation - Silver PSU: step 7, image 2 of 3 08. LCD screen and PSU, PSU installation - Silver PSU: step 7, image 3 of 3
      • Rotate the frame to the right side. Carefully guide the extruder to the right. Do not let it slide freely into the x-ends..
      • Slide 2x t-nuts into the extrusion from the top of the frame, as shown.
      • Position the PSU and secure it with 2x M5x10 screws. Do not tighten them fully yet.
      Ask FixBot
    8. 08. LCD screen and PSU, PSU installation - Silver PSU: step 8, image 1 of 3 08. LCD screen and PSU, PSU installation - Silver PSU: step 8, image 2 of 3 08. LCD screen and PSU, PSU installation - Silver PSU: step 8, image 3 of 3
      • Secure the bottom of the PSU with an M3 screw reused from your Original Prusa, do not tighten fully yet. This screw has a different length depending on which Prusa model you have:
      • MK2(S) or MK2.5(S): length can be 18mm or 25mm (both are compatible with the psu_lower_mount).
      • MK3(S): 10mm long.
      • Verify that the PSU cables are not pinched and pass under the Y axis smooth rod.
      • Adjust the PSU position to be flush with the extrusion at the rear of the frame.
      • Fully tighten evenly, incrementally and in turn the screws of psu_lower_mount and psu_upper_mount.
      • Verify that the PSU cables aren't pinched and pass under the Y axis smooth rod.
      Ask FixBot
    9. 08. LCD screen and PSU, Next chapter: step 9, image 1 of 1
      Ask FixBot
    10. 08. LCD screen and PSU, PSU type: step 10, image 1 of 2 08. LCD screen and PSU, PSU type: step 10, image 2 of 2
      • The next steps are for the Prusa black PSU only.
      • If you have the Prusa silver PSU, go to step 5
      • Prusa black PSU
      • Prusa silver PSU
      Ask FixBot
    11. 08. LCD screen and PSU, PSU upper mount assembly - Black PSU: step 11, image 1 of 2 08. LCD screen and PSU, PSU upper mount assembly - Black PSU: step 11, image 2 of 2
      • Attach the psu_upper_mounts to the black PSU body. Fully tighten the M4 screws, ensuring that the PSU mounts are properly positioned and aligned .
      Ask FixBot
    12. 08. LCD screen and PSU, PSU lower mount assembly - Black PSU: step 12, image 1 of 3 08. LCD screen and PSU, PSU lower mount assembly - Black PSU: step 12, image 2 of 3 08. LCD screen and PSU, PSU lower mount assembly - Black PSU: step 12, image 3 of 3
      • Slide 1x t-nut into the top channel of the rear extrusion, from the right side of the frame.
      Ask FixBot
    13. 08. LCD screen and PSU, PSU installation - Black PSU: step 13, image 1 of 3 08. LCD screen and PSU, PSU installation - Black PSU: step 13, image 2 of 3 08. LCD screen and PSU, PSU installation - Black PSU: step 13, image 3 of 3
      Ask FixBot
    14. 08. LCD screen and PSU, PSU installation - Black PSU: step 14, image 1 of 3 08. LCD screen and PSU, PSU installation - Black PSU: step 14, image 2 of 3 08. LCD screen and PSU, PSU installation - Black PSU: step 14, image 3 of 3
      • Remove the PSU cover (with Prusa logo) by unscrewing the 2x M3x10 screws.
      • Take an extra M3x10 (reused from your Original Prusa) screw and secure the PSU to the psu_lower_mount. Do not tighten fully yet.
      • Verify that the PSU cables are not pinched and that they go out of the back of the PSU and pass under the Y axis smooth rod.
      • Verify that the PSU cables are not pinched and are routed correctly.
      Ask FixBot
    15. 08. LCD screen and PSU, PSU installation - Black PSU: step 15, image 1 of 2 08. LCD screen and PSU, PSU installation - Black PSU: step 15, image 2 of 2
      • Reassemble the PSU cover with 2x M3x10 screws (reused from your Original Prusa).
      • Verify again that PSU cables aren't pinched and are correctly routed.
      Ask FixBot
    16. 08. LCD screen and PSU, Next chapter: step 16, image 1 of 1
      Ask FixBot
Finish Line
Greg Bear
8,773 Reputation
35 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 41
All Time: 41
