Xbox One S Optical Drive Assembly
  1. Xbox One S Optical Drive Assembly, Case: step 1, image 1 of 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
    Ask FixBot
  2. Xbox One S Optical Drive Assembly: step 2, image 1 of 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
    Ask FixBot
  3. Xbox One S Optical Drive Assembly: step 3, image 1 of 1
    • Once all of the clips are opened, remove the bottom part of the case.
    Ask FixBot
  4. Xbox One S Optical Drive Assembly: step 4, image 1 of 2 Xbox One S Optical Drive Assembly: step 4, image 2 of 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    Ask FixBot
  5. Xbox One S Optical Drive Assembly: step 5, image 1 of 2 Xbox One S Optical Drive Assembly: step 5, image 2 of 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
    Ask FixBot
  6. Xbox One S Optical Drive Assembly, Interior Case Top Panel: step 6, image 1 of 1
    • Flip the interior case so it is fan side upward.
    Ask FixBot
  7. Xbox One S Optical Drive Assembly: step 7, image 1 of 1
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
    Ask FixBot
  8. Xbox One S Optical Drive Assembly, Hard Drive Assembly: step 8, image 1 of 2 Xbox One S Optical Drive Assembly, Hard Drive Assembly: step 8, image 2 of 2
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C5, from the backside of the Xbox One S.
    • Some models may require C4 and C5.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
    Ask FixBot
  9. Xbox One S Optical Drive Assembly: step 9, image 1 of 3 Xbox One S Optical Drive Assembly: step 9, image 2 of 3 Xbox One S Optical Drive Assembly: step 9, image 3 of 3
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    Ask FixBot
  10. Xbox One S Optical Drive Assembly, Optical Drive Assembly: step 10, image 1 of 1
    • To remove the optical disc drive, remove the silver 10 mm T-10 Torx screw labeled "C4."
    Ask FixBot
  11. Xbox One S Optical Drive Assembly: step 11, image 1 of 1
    • Pull the disc drive slightly off the motherboard and disconnect the plastic connectors from the motherboard.
    Ask FixBot
21 other people completed this guide.
Victoria Law
1,117 Reputation
3 Guides authored
Cal Poly, Team S22-G3, Livingston Spring 2017 Member of Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Members
59 Guides authored
3 Guide Comments
alles schwachsinn: habe an meiner xbox one s dfas optische Laufwerk ausgetauscht ,da beim alten die spiele immer einfrohren .Alles nach Anleitung wie hier beschrieben . nun geht Garnichts mehr , kein bild kein ton geschweige noch ein spiel neu zu installiren .
siegfrieheide - Reply Share
Das Problem ist, dass Microsoft das Laufwerk und die Hauptplatine “verheiratet" hat. Man kann also nur ein Laufwerk mitsamt der zugehörigen Hauptplatine austauschen.
VauWeh - Reply Share
Muy bien explicado. Tengo un problema, ya que remplacé la unidad de disco, la consola prende y funciona, pero marca que hay error con la unidad, que puedo usar la consola peor no leer discos... Agradecería me pudieran orientar. Saludos
Rodolfo Alberto - Reply Share
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 175
All Time: 13,109
