Google Pixel 9 5G mmWave Antenna Replacement
  1. Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: step 1, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: step 1, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: step 1, image 3 of 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Ask FixBot
  2. Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: step 2, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: step 2, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
    Ask FixBot
  3. Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: step 3, image 1 of 2 Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: step 3, image 2 of 2
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
    Ask FixBot
  4. Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: step 4, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: step 4, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  5. Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: step 5, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: step 5, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: step 5, image 3 of 3
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    Ask FixBot
  6. Google Pixel 9 5G mmWave Antenna Replacement: step 6, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement: step 6, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement: step 6, image 3 of 3
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
    Ask FixBot
  7. Google Pixel 9 5G mmWave Antenna Replacement: step 7, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement: step 7, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement: step 7, image 3 of 3
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
    Ask FixBot
  8. Google Pixel 9 5G mmWave Antenna Replacement, Remove the back glass: step 8, image 1 of 1
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
    Ask FixBot
  9. Google Pixel 9 5G mmWave Antenna Replacement, Remove the upper board cover: step 9, image 1 of 1
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
    Ask FixBot
  10. Google Pixel 9 5G mmWave Antenna Replacement: step 10, image 1 of 2 Google Pixel 9 5G mmWave Antenna Replacement: step 10, image 2 of 2
    • Use a pair of tweezers to remove the upper board cover.
    Ask FixBot
  11. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: step 11, image 1 of 1
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
    Ask FixBot
  12. Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: step 12, image 1 of 2 Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: step 12, image 2 of 2
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
    Ask FixBot
  13. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: step 13, image 1 of 2 Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: step 13, image 2 of 2
    • Remove the midframe, wireless charging coil, and NFC assembly.
    Ask FixBot
  14. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: step 14, image 1 of 2 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: step 14, image 2 of 2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    Ask FixBot
  15. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: step 15, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: step 15, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: step 15, image 3 of 3
    • Use the tip of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
    Ask FixBot
  16. Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: step 16, image 1 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: step 16, image 2 of 3 Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: step 16, image 3 of 3
    • Remove the 5G mmWave antenna.
    • A small flex cable attaches to the back of the antenna with a press connector. You may need to reconnect it if it falls off.
    • During reassembly, insert the antenna so it's between the frame and the small metal bracket near the top right corner.
    Ask FixBot
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
165,456 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 32
Past 30 Days: 173
All Time: 3,492
