iPhone 15 Plus Microphone Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
203
All Time:
3,904
Comments: 31
31 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the microphone in your iPhone 15 Plus.
If your iPhone's having a hard time picking up your voice, or has intermittent issues, the microphone might need to be replaced.
The microphone in this guide is the primary of three microphones, and can be replaced as a single unit. Another microphone is integrated with the charging port assembly, and a third is integrated with the power button assembly.
You'll need replacement back glass adhesive to complete this repair.
Parts
  • Tesa 61395 Double-Sided Tape
    4.9
    Optional
Tools
    1. iPhone 15 Plus Microphone Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Plus Microphone Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Plus Microphone Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Plus Microphone Replacement, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Plus Microphone Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Plus Microphone Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Plus Microphone Replacement, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 15 Plus Microphone Replacement, Remove the pentalobe screws: step 4, image 1 of 1
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Plus Microphone Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    2. iPhone 15 Plus Microphone Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Plus Microphone Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Plus Microphone Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    3. iPhone 15 Plus Microphone Replacement, Back glass information: step 7, image 1 of 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      Ask FixBot
    4. iPhone 15 Plus Microphone Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Plus Microphone Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Plus Microphone Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Plus Microphone Replacement, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Plus Microphone Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 3 iPhone 15 Plus Microphone Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 3 iPhone 15 Plus Microphone Replacement, Separate the bottom right corner adhesive: step 10, image 3 of 3
      • Don't insert your pick deeper than 7 mm along the right edge.
      • Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
      • Don't slice near the volume buttons to avoid damaging the wireless charging cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone 15 Plus Microphone Replacement, Heat the left edge: step 11, image 1 of 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Ask FixBot
    8. iPhone 15 Plus Microphone Replacement, Separate the left edge adhesive: step 12, image 1 of 3 iPhone 15 Plus Microphone Replacement, Separate the left edge adhesive: step 12, image 2 of 3 iPhone 15 Plus Microphone Replacement, Separate the left edge adhesive: step 12, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the left edge.
      • Insert a second opening pick at the bottom edge.
      • Rotate the second pick around the bottom left corner.
      • Slide this pick up to the top left corner to separate the adhesive.
      Ask FixBot
    9. iPhone 15 Plus Microphone Replacement, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Ask FixBot
    10. iPhone 15 Plus Microphone Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Plus Microphone Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Plus Microphone Replacement, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
      • You might hear and feel clicks as the top two clips release.
      • Leave this pick in place to prevent the adhesive from resealing.
      Ask FixBot
    11. iPhone 15 Plus Microphone Replacement, Heat the top right corner: step 15, image 1 of 1
      • Heat the top right corner of the back glass until it's hot to the touch.
      Ask FixBot
    12. iPhone 15 Plus Microphone Replacement, Separate the top right corner adhesive: step 16, image 1 of 3 iPhone 15 Plus Microphone Replacement, Separate the top right corner adhesive: step 16, image 2 of 3 iPhone 15 Plus Microphone Replacement, Separate the top right corner adhesive: step 16, image 3 of 3
      • Don't insert your pick deeper than 4 mm along the right edge.
      • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
      Ask FixBot
    13. iPhone 15 Plus Microphone Replacement, Swing open the back glass: step 17, image 1 of 2 iPhone 15 Plus Microphone Replacement, Swing open the back glass: step 17, image 2 of 2
      • Gently swing open the back glass to the right of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a raised surface so it doesn't strain the cable.
      Ask FixBot
    1. iPhone 15 Plus Microphone Replacement, Unfasten the lower connector cover: step 18, image 1 of 2 iPhone 15 Plus Microphone Replacement, Unfasten the lower connector cover: step 18, image 2 of 2
      Tool used on this step:
      FixMat
      $36.95
      Buy
      • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
      Ask FixBot
    2. iPhone 15 Plus Microphone Replacement, Remove the lower connector cover: step 19, image 1 of 3 iPhone 15 Plus Microphone Replacement, Remove the lower connector cover: step 19, image 2 of 3 iPhone 15 Plus Microphone Replacement, Remove the lower connector cover: step 19, image 3 of 3
      Buy
      • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
      • Remove the cover.
      Ask FixBot
    3. iPhone 15 Plus Microphone Replacement: step 20, image 1 of 3 iPhone 15 Plus Microphone Replacement: step 20, image 2 of 3 iPhone 15 Plus Microphone Replacement: step 20, image 3 of 3
      • Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
      • A plus and minus sign is printed on the head of this connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Ask FixBot
    1. iPhone 15 Plus Microphone Replacement, Unfasten the Taptic Engine connector cover: step 21, image 1 of 1
      • Use your Phillips #000 driver to remove the four screws securing the Taptic Engine and its connector cover:
      • One 1.4 mm‑long screw
      • One 1.9 mm‑long screw (larger screw head)
      • One 1.9 mm‑long screw (smaller screw head)
      • One 2.1 mm‑long screw
      Ask FixBot
    2. iPhone 15 Plus Microphone Replacement, Remove the cover: step 22, image 1 of 2 iPhone 15 Plus Microphone Replacement, Remove the cover: step 22, image 2 of 2
      Buy
      • Use tweezers to remove the Taptic Engine connector cover.
      • During reassembly, orient the cover so that its gold spring contact is closest to the edge of the frame.
      Ask FixBot
    3. iPhone 15 Plus Microphone Replacement, Disconnect the Taptic Engine: step 23, image 1 of 2 iPhone 15 Plus Microphone Replacement, Disconnect the Taptic Engine: step 23, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the Taptic Engine press connector.
      Ask FixBot
    4. iPhone 15 Plus Microphone Replacement, Unfasten the Taptic Engine: step 24, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Use a standoff driver to remove the 3.3 mm screw securing the top left of the Taptic Engine.
      • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
      Ask FixBot
    5. iPhone 15 Plus Microphone Replacement, Remove the Taptic Engine: step 25, image 1 of 2 iPhone 15 Plus Microphone Replacement, Remove the Taptic Engine: step 25, image 2 of 2
      • Use tweezers or your fingers to remove the Taptic Engine.
      Ask FixBot
    1. iPhone 15 Plus Microphone Replacement, Unfasten the loudspeaker: step 26, image 1 of 1
      • Use your tri-point Y000 driver to remove the 1.3 mm screw securing a grounding contact and the loudspeaker.
      • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
      • Two 1.6 mm screws
      • Two 2.0 mm screws
      Ask FixBot
    2. iPhone 15 Plus Microphone Replacement, Remove the loudspeaker: step 27, image 1 of 2 iPhone 15 Plus Microphone Replacement, Remove the loudspeaker: step 27, image 2 of 2
      • Grab the loudspeaker and remove it.
      Ask FixBot
    1. iPhone 15 Plus Microphone Replacement, Disconnect the microphone: step 28, image 1 of 2 iPhone 15 Plus Microphone Replacement, Disconnect the microphone: step 28, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the microphone press connector.
      Ask FixBot
    2. iPhone 15 Plus Microphone Replacement, Unfasten the microphone: step 29, image 1 of 1
      • Use your tri-point Y000 driver to remove the 1.3 mm screw securing a grounding contact and the microphone.
      • Use your Phillips #000 driver to remove the two screws securing the right side of the microphone:
      • One 1.9 mm screw
      • One 1.3 mm screw
      • Use your standoff driver to remove the 3.2 mm standoff screw securing the top left of the microphone.
      Ask FixBot
    3. iPhone 15 Plus Microphone Replacement, Remove the microphone: step 30, image 1 of 3 iPhone 15 Plus Microphone Replacement, Remove the microphone: step 30, image 2 of 3 iPhone 15 Plus Microphone Replacement, Remove the microphone: step 30, image 3 of 3
      Tesa 61395 Tape
      $10.95
      Buy
      • Insert the flat end of a spudger under the top right screw mount of the microphone and pry up until you can grab it with your fingers.
      • Peel the microphone from the adhesive securing it to the frame and remove it.
      • During reassembly, you may replace the adhesive that secures the microphone with thin, double-sided tape, but make sure your new adhesive doesn't block the sound cutouts.
      Ask FixBot
To reassemble your phone, follow these instructions in reverse order.
Clay Eickemeyer
108,426 Reputation
471 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,178 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 203
All Time: 3,904
