Introduction
Follow this guide to remove and replace the laser on a PlayStation 5.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers or your fingernail to remove the cap from the cubby.
Use your finger to press the cap into the screw hole.
If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
Lift the stand straight up to remove it.
Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
Lift up the corner of the faceplate to unclip it from the case.
Insert the flat end of a spudger underneath the grille and into the gap above the fan.
Lift up with the spudger to pry the grille away from the case.
Tool used on this step:Magnetic Project Mat$19.95
Use a TR9 Torx Security driver to remove the four screws securing the fan shroud to the case:
Two 23.3 mm-long screws
One 11.4 mm-long screw
One 31 mm-long screw
Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
Use the spudger to peel up the wire cover until you can grip it with your fingers.
Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
Use a TR8 Torx Security driver to remove the eleven screws securing the case:
Six 18.6 mm-long screws
Two 43.2 mm-long screws
One 7.3 mm-long screw
Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
silver screws: 4x M1.6 X 3.7mm, with 6.5mm head.
black screws: 9x M1.6 x 3.8mm.
Remove screws with Phillips #1 screwdriver.
Gently pull the medium and narrow FFC flexes and the 2-wire lead from their sockets. Suitable tweezers (bent with points or straight blunt end) can be used to aid removal.
black screws: 2x M1.6 x 3.8mm
Unlatch the wide FFC socket.
Gently remove the wide FFC cable from the socket and set aside the PCB.
Use a Phillips #1 screwdriver to remove the screws.
black screws: 4x M1.6 x 3.8mm.
Push down on the roller mech and remove the FFC cable from laser deck (near roller mech).
silver screws: 2x M1.7 X 3.8mm
black screw: 1x M1.4 x 3.9mm
unlatch the FFC connector.
Remove the FFC flex from the laser.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
18 other people completed this guide.
6 Guide Comments
Danke für die tolle und ausführliche Anleitung!
Discs werden wieder gelesen *freu*
Please be advised: during Optical Drive reassembly, it is crucial that a notch/peg be fitted into its corresponding groove seen in Step33. In the image the notch and groove can be seen in the upper most circular white piece and at the 11 o'clock position. This must be done for the drive to work appropriately. -ljr
