PlayStation 5 Faceplate Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. PlayStation 5 Faceplate Replacement, Faceplate: step 1, image 1 of 3 PlayStation 5 Faceplate Replacement, Faceplate: step 1, image 2 of 3 PlayStation 5 Faceplate Replacement, Faceplate: step 1, image 3 of 3
    • Make sure the PS5 console is turned off, and no wires are connected to the ports.
    • Place the PS5 console horizontally with the PlayStation logo facing upfront.
    • Use a soft work surface to protect the device.
    Ask FixBot
  2. PlayStation 5 Faceplate Replacement: step 2, image 1 of 2 PlayStation 5 Faceplate Replacement: step 2, image 2 of 2
    • Remove the PS5 stand from the console by unscrewing a slotted flat head screw located at the bottom of the stand with a slotted screwdriver.
    Ask FixBot
  3. PlayStation 5 Faceplate Replacement: step 3, image 1 of 2 PlayStation 5 Faceplate Replacement: step 3, image 2 of 2
    • After unscrewing, use your hand to lift the PS5 console from one side.
    • Use your other hand to remove the PS5 stand.
    Ask FixBot
  4. PlayStation 5 Faceplate Replacement: step 4, image 1 of 3 PlayStation 5 Faceplate Replacement: step 4, image 2 of 3 PlayStation 5 Faceplate Replacement: step 4, image 3 of 3
    • Using your fingers, pull the side plate upwards from the corner of the PlayStation logo.
    • While pulling up the side plate, use your other hand on the opposite corner of the PlayStation logo to push the side plate down until you hear a click sound.
    • Remove the side plate from the PS5 console.
    Ask FixBot
  5. PlayStation 5 Faceplate Replacement: step 5, image 1 of 3 PlayStation 5 Faceplate Replacement: step 5, image 2 of 3 PlayStation 5 Faceplate Replacement: step 5, image 3 of 3
    • Flip the PS5 console over with its rear ports facing towards you.
    Ask FixBot
  6. PlayStation 5 Faceplate Replacement: step 6, image 1 of 3 PlayStation 5 Faceplate Replacement: step 6, image 2 of 3 PlayStation 5 Faceplate Replacement: step 6, image 3 of 3
    • Using your fingers, pull up the faceplate from the bottom right corner while using your other hand at the opposite corner to push the side plate downwards.
    • Attempt this until you hear a click sound.
    Ask FixBot
  7. PlayStation 5 Faceplate Replacement: step 7, image 1 of 2 PlayStation 5 Faceplate Replacement: step 7, image 2 of 2
    • Put the new side plate on by placing it on top of the console and aligning its hooks with its corresponding holes.
    • Use your hand to push the plate from the bottom while pulling up one of the corners of the side plate on the opposite side.
    • Repeat the previous step for the other side plate.
    Ask FixBot
2 other people completed this guide.
Syed Asif
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 697
