Xbox Series X Back Panel Replacement
  1. Xbox Series X Back Panel Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X Back Panel Replacement, Uncover the back panel screws: step 1, image 2 of 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
    Ask FixBot
  2. Xbox Series X Back Panel Replacement: step 2, image 1 of 3 Xbox Series X Back Panel Replacement: step 2, image 2 of 3 Xbox Series X Back Panel Replacement: step 2, image 3 of 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    Ask FixBot
  3. Xbox Series X Back Panel Replacement, Remove the back panel screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    Ask FixBot
  4. Xbox Series X Back Panel Replacement, Unclip the back panel: step 4, image 1 of 3 Xbox Series X Back Panel Replacement, Unclip the back panel: step 4, image 2 of 3 Xbox Series X Back Panel Replacement, Unclip the back panel: step 4, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
    Ask FixBot
  5. Xbox Series X Back Panel Replacement: step 5, image 1 of 2 Xbox Series X Back Panel Replacement: step 5, image 2 of 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
    Ask FixBot
  6. Xbox Series X Back Panel Replacement, Remove the back panel: step 6, image 1 of 3 Xbox Series X Back Panel Replacement, Remove the back panel: step 6, image 2 of 3 Xbox Series X Back Panel Replacement, Remove the back panel: step 6, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
    Ask FixBot
  7. Xbox Series X Back Panel Replacement: step 7, image 1 of 3 Xbox Series X Back Panel Replacement: step 7, image 2 of 3 Xbox Series X Back Panel Replacement: step 7, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
3 other people completed this guide.
Carsten Frauenheim
165,456 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 168
Past 30 Days: 761
All Time: 7,951
