PlayStation 5 Power Supply Replacement
  1. PlayStation 5 Power Supply Replacement, Remove the stand screw: step 1, image 1 of 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
    Ask FixBot
  2. PlayStation 5 Power Supply Replacement, Remove the vertical stand: step 2, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the vertical stand: step 2, image 2 of 2
    • Lift straight up to remove the stand.
    Ask FixBot
  3. PlayStation 5 Power Supply Replacement, Store the stand screw: step 3, image 1 of 2 PlayStation 5 Power Supply Replacement, Store the stand screw: step 3, image 2 of 2
    • Insert the screw into the cubby on the bottom of the stand.
    Ask FixBot
  4. PlayStation 5 Power Supply Replacement, Cap the screw hole: step 4, image 1 of 3 PlayStation 5 Power Supply Replacement, Cap the screw hole: step 4, image 2 of 3 PlayStation 5 Power Supply Replacement, Cap the screw hole: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
    Ask FixBot
  5. PlayStation 5 Power Supply Replacement, Close the cubby: step 5, image 1 of 3 PlayStation 5 Power Supply Replacement, Close the cubby: step 5, image 2 of 3 PlayStation 5 Power Supply Replacement, Close the cubby: step 5, image 3 of 3
    • Twist the stand counterclockwise to close the cubby.
    Ask FixBot
  6. PlayStation 5 Power Supply Replacement, Remove the horizontal stand: step 6, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the horizontal stand: step 6, image 2 of 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
    Ask FixBot
  7. PlayStation 5 Power Supply Replacement, Remove the right faceplate: step 7, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the right faceplate: step 7, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the right faceplate: step 7, image 3 of 3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
    Ask FixBot
  8. PlayStation 5 Power Supply Replacement: step 8, image 1 of 2 PlayStation 5 Power Supply Replacement: step 8, image 2 of 2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
    Ask FixBot
  9. PlayStation 5 Power Supply Replacement, Pry up the grille: step 9, image 1 of 3 PlayStation 5 Power Supply Replacement, Pry up the grille: step 9, image 2 of 3 PlayStation 5 Power Supply Replacement, Pry up the grille: step 9, image 3 of 3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
    Ask FixBot
  10. PlayStation 5 Power Supply Replacement, Remove the grille: step 10, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the grille: step 10, image 2 of 2
    • Lift the grille away from the case to remove it.
    Ask FixBot
  11. PlayStation 5 Power Supply Replacement, Remove the fan shroud screws: step 11, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a TR9 Torx Security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    Ask FixBot
  12. PlayStation 5 Power Supply Replacement, Remove the fan shroud: step 12, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the fan shroud: step 12, image 2 of 2
    • Lift the fan shroud straight up to remove it.
    Ask FixBot
  13. PlayStation 5 Power Supply Replacement, Remove the wire cover: step 13, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the wire cover: step 13, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the wire cover: step 13, image 3 of 3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
    Ask FixBot
  14. PlayStation 5 Power Supply Replacement: step 14, image 1 of 3 PlayStation 5 Power Supply Replacement: step 14, image 2 of 3 PlayStation 5 Power Supply Replacement: step 14, image 3 of 3
    • Use your fingers to peel off the wire cover.
    Ask FixBot
  15. PlayStation 5 Power Supply Replacement, Disconnect the fan: step 15, image 1 of 2 PlayStation 5 Power Supply Replacement, Disconnect the fan: step 15, image 2 of 2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
    Ask FixBot
  16. PlayStation 5 Power Supply Replacement, Remove the fan: step 16, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the fan: step 16, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the fan: step 16, image 3 of 3
    • Lift the fan up and out of the case to remove it.
    Ask FixBot
  17. PlayStation 5 Power Supply Replacement, Remove the SSD cover: step 17, image 1 of 1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
    Ask FixBot
  18. PlayStation 5 Power Supply Replacement: step 18, image 1 of 3 PlayStation 5 Power Supply Replacement: step 18, image 2 of 3 PlayStation 5 Power Supply Replacement: step 18, image 3 of 3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
    Ask FixBot
  19. PlayStation 5 Power Supply Replacement, Remove the optical drive wire: step 19, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the optical drive wire: step 19, image 2 of 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
    Ask FixBot
  20. PlayStation 5 Power Supply Replacement: step 20, image 1 of 2 PlayStation 5 Power Supply Replacement: step 20, image 2 of 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
    Ask FixBot
  21. PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: step 21, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: step 21, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: step 21, image 3 of 3
    Buy
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
    Ask FixBot
  22. PlayStation 5 Power Supply Replacement, Remove the case screws: step 22, image 1 of 1
    • Use a TR8 Torx Security driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
    Ask FixBot
  23. PlayStation 5 Power Supply Replacement, Remove the case: step 23, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the case: step 23, image 2 of 2
    • Lift the case straight up to remove it.
    Ask FixBot
  24. PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: step 24, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: step 24, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: step 24, image 3 of 3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
    Ask FixBot
  25. PlayStation 5 Power Supply Replacement, Remove the optical drive: step 25, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the optical drive: step 25, image 2 of 2
    • Lift the optical drive away from the device to remove it.
    Ask FixBot
  26. PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: step 26, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: step 26, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: step 26, image 3 of 3
    Buy
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
    Ask FixBot
  27. PlayStation 5 Power Supply Replacement, Remove the power and eject button ribbon cable: step 27, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the power and eject button ribbon cable: step 27, image 2 of 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
    Ask FixBot
  28. PlayStation 5 Power Supply Replacement, Remove the LED ribbon cable: step 28, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the LED ribbon cable: step 28, image 2 of 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
    Ask FixBot
  29. PlayStation 5 Power Supply Replacement, Remove the antenna wires: step 29, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the antenna wires: step 29, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the antenna wires: step 29, image 3 of 3
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
    Ask FixBot
  30. PlayStation 5 Power Supply Replacement: step 30, image 1 of 3 PlayStation 5 Power Supply Replacement: step 30, image 2 of 3 PlayStation 5 Power Supply Replacement: step 30, image 3 of 3
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
    Ask FixBot
  31. PlayStation 5 Power Supply Replacement, Remove the white stickers: step 31, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the white stickers: step 31, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the white stickers: step 31, image 3 of 3
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
    Ask FixBot
  32. PlayStation 5 Power Supply Replacement: step 32, image 1 of 3 PlayStation 5 Power Supply Replacement: step 32, image 2 of 3 PlayStation 5 Power Supply Replacement: step 32, image 3 of 3
    • Repeat the previous step to peel back the four remaining stickers.
    Ask FixBot
  33. PlayStation 5 Power Supply Replacement: step 33, image 1 of 3 PlayStation 5 Power Supply Replacement: step 33, image 2 of 3 PlayStation 5 Power Supply Replacement: step 33, image 3 of 3
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
    Ask FixBot
  34. PlayStation 5 Power Supply Replacement, Remove the top shield plate screws: step 34, image 1 of 1
    • Use a TR8 Torx Security driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
    Ask FixBot
  35. PlayStation 5 Power Supply Replacement, Remove the top shield plate: step 35, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the top shield plate: step 35, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the top shield plate: step 35, image 3 of 3
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
    Ask FixBot
  36. PlayStation 5 Power Supply Replacement, Disconnect the USB board: step 36, image 1 of 3 PlayStation 5 Power Supply Replacement, Disconnect the USB board: step 36, image 2 of 3 PlayStation 5 Power Supply Replacement, Disconnect the USB board: step 36, image 3 of 3
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
    Ask FixBot
  37. PlayStation 5 Power Supply Replacement, Remove the left faceplate: step 37, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the left faceplate: step 37, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the left faceplate: step 37, image 3 of 3
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
    Ask FixBot
  38. PlayStation 5 Power Supply Replacement: step 38, image 1 of 2 PlayStation 5 Power Supply Replacement: step 38, image 2 of 2
    • Remove the left faceplate.
    Ask FixBot
  39. PlayStation 5 Power Supply Replacement, Remove the screws: step 39, image 1 of 1
    • Use a TR8 Torx Security driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
    Ask FixBot
  40. PlayStation 5 Power Supply Replacement, Remove the case: step 40, image 1 of 3 PlayStation 5 Power Supply Replacement, Remove the case: step 40, image 2 of 3 PlayStation 5 Power Supply Replacement, Remove the case: step 40, image 3 of 3
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
    • The front plate may come apart from the plastic case. During reassembly, make sure the front plate is in place before reinserting the motherboard and power supply.
    Ask FixBot
  41. PlayStation 5 Power Supply Replacement, Remove the power supply: step 41, image 1 of 2 PlayStation 5 Power Supply Replacement, Remove the power supply: step 41, image 2 of 2
    • Use a finger to hold the rear shield plate down against the work surface.
    • Grip the power supply and lift it straight up to disconnect it from the motherboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
52 other people completed this guide.
Robert Boyd
33,206 Reputation
94 Guides authored
21 Guide Comments
Is there any place to buy a replacement power supply?
anon - Reply Share
Where can I get the power supply unit which is Model ADP-400DR ? Please help me
Addis - Reply Share
egamephone have ps5 power supply replacement
kasynlife - Reply Share
So I started with a dead PS5. I had another power supply laying about but from a different revision. I replaced the power supply with said other power supply that works. When I put it back together still no power. Does each revision used a different power supply or would it be the same?
askanison420 - Reply Share
i’m having the same problem, did you ever get it to work?
abrey - Reply Share
Past 24 Hours: 95
Past 7 Days: 873
Past 30 Days: 3,709
All Time: 193,740
