Xbox Series S Fan Replacement
  1. Xbox Series S Fan Replacement, Peel off the sticker coverings: step 1, image 1 of 3 Xbox Series S Fan Replacement, Peel off the sticker coverings: step 1, image 2 of 3 Xbox Series S Fan Replacement, Peel off the sticker coverings: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    Ask FixBot
  2. Xbox Series S Fan Replacement, Remove the back panel screws: step 2, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
    Ask FixBot
  3. Xbox Series S Fan Replacement, Remove the bottom panel: step 3, image 1 of 3 Xbox Series S Fan Replacement, Remove the bottom panel: step 3, image 2 of 3 Xbox Series S Fan Replacement, Remove the bottom panel: step 3, image 3 of 3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
    Ask FixBot
  4. Xbox Series S Fan Replacement, Remove the plastic case screws: step 4, image 1 of 1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
    Ask FixBot
  5. Xbox Series S Fan Replacement, Remove the plastic case: step 5, image 1 of 3 Xbox Series S Fan Replacement, Remove the plastic case: step 5, image 2 of 3 Xbox Series S Fan Replacement, Remove the plastic case: step 5, image 3 of 3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
    Ask FixBot
  6. Xbox Series S Fan Replacement: step 6, image 1 of 3 Xbox Series S Fan Replacement: step 6, image 2 of 3 Xbox Series S Fan Replacement: step 6, image 3 of 3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
    Ask FixBot
  7. Xbox Series S Fan Replacement, Remove the power supply screws: step 7, image 1 of 1
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
    Ask FixBot
  8. Xbox Series S Fan Replacement, Remove the upper chassis: step 8, image 1 of 2 Xbox Series S Fan Replacement, Remove the upper chassis: step 8, image 2 of 2
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
    Ask FixBot
  9. Xbox Series S Fan Replacement, Remove the power supply: step 9, image 1 of 3 Xbox Series S Fan Replacement, Remove the power supply: step 9, image 2 of 3 Xbox Series S Fan Replacement, Remove the power supply: step 9, image 3 of 3
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
    Ask FixBot
  10. Xbox Series S Fan Replacement, Remove the fan screws: step 10, image 1 of 1
    • Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
    Ask FixBot
  11. Xbox Series S Fan Replacement, Disconnect the fan: step 11, image 1 of 2 Xbox Series S Fan Replacement, Disconnect the fan: step 11, image 2 of 2
    • Take care when flipping the chassis over because the fan is now loose.
    • Use your fingers to pull and disconnect the fan connector from its motherboard socket.
    • Take care not to pull on the wires when disconnecting the fan to prevent breaking the connector.
    • This connector may be difficult to remove. A good method to remove it is to shimmy the connector up and out of its socket with a spudger.
    • You may be able to remove this connector without removing the power supply with a pair of needle-nose pliers.
    Ask FixBot
  12. Xbox Series S Fan Replacement, Remove the fan: step 12, image 1 of 2 Xbox Series S Fan Replacement, Remove the fan: step 12, image 2 of 2
    • Lift the fan straight up to remove it from the motherboard.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
36 other people completed this guide.
Robert Boyd
33,206 Reputation
94 Guides authored
2 Guide Comments
what kind of pin connector does the fan use? i want to see if it’s possible to attach a fan splitter y cable.
Sir Yeeks - Reply Share
Hi wondering if I’m able to switch out the fan to another fan like a noctua fan but I don’t know what fab size?
bp.guevara87 - Reply Share
Past 24 Hours: 26
Past 7 Days: 194
Past 30 Days: 944
All Time: 41,770
