Xbox Series S Bluetooth Board Replacement
  1. Xbox Series S Bluetooth Board Replacement, Peel off the sticker coverings: step 1, image 1 of 3 Xbox Series S Bluetooth Board Replacement, Peel off the sticker coverings: step 1, image 2 of 3 Xbox Series S Bluetooth Board Replacement, Peel off the sticker coverings: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    Ask FixBot
  2. Xbox Series S Bluetooth Board Replacement, Remove the back panel screws: step 2, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
    Ask FixBot
  3. Xbox Series S Bluetooth Board Replacement, Remove the bottom panel: step 3, image 1 of 3 Xbox Series S Bluetooth Board Replacement, Remove the bottom panel: step 3, image 2 of 3 Xbox Series S Bluetooth Board Replacement, Remove the bottom panel: step 3, image 3 of 3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
    Ask FixBot
  4. Xbox Series S Bluetooth Board Replacement, Remove the plastic case screws: step 4, image 1 of 1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
    Ask FixBot
  5. Xbox Series S Bluetooth Board Replacement, Remove the plastic case: step 5, image 1 of 3 Xbox Series S Bluetooth Board Replacement, Remove the plastic case: step 5, image 2 of 3 Xbox Series S Bluetooth Board Replacement, Remove the plastic case: step 5, image 3 of 3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
    Ask FixBot
  6. Xbox Series S Bluetooth Board Replacement: step 6, image 1 of 3 Xbox Series S Bluetooth Board Replacement: step 6, image 2 of 3 Xbox Series S Bluetooth Board Replacement: step 6, image 3 of 3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
    Ask FixBot
  7. Xbox Series S Bluetooth Board Replacement, Remove the Bluetooth board: step 7, image 1 of 1
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Bluetooth board to the long edge of the chassis.
    Ask FixBot
  8. Xbox Series S Bluetooth Board Replacement: step 8, image 1 of 3 Xbox Series S Bluetooth Board Replacement: step 8, image 2 of 3 Xbox Series S Bluetooth Board Replacement: step 8, image 3 of 3
    • Use a spudger to pry and loosen the Bluetooth board.
    • Do not pry from the bottom or sides of the Bluetooth board as it may bend the connector.
    • Pull the Bluetooth board straight out to disconnect it from the chassis.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 other people completed this guide.
Robert Boyd
33,206 Reputation
94 Guides authored
3 Guide Comments
So I just followed the disassemble guide just to clean the dust out of my series s. When I reassembled the device the controllers were no longer synced and the sync button clicks as it should but it no longer syncing my controllers. I've tried with a cord and the sync then but once the cord is removed they go back to trying to sync and the button on the console is not activating. Do I need a new module
Shawn Wegner - Reply Share
Yes it does same thing happened to I just ordered one cause it won’t even pair by usb
content simps - Reply Share
Mind you everything else works the system starts up goes online and plays games
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 211
All Time: 8,217
