Xbox One X Power Supply Replacement
  1. Xbox One X Power Supply Replacement, Remove the sticker: step 1, image 1 of 2 Xbox One X Power Supply Replacement, Remove the sticker: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    Ask FixBot
  2. Xbox One X Power Supply Replacement, Remove the external screws: step 2, image 1 of 1
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
    Ask FixBot
  3. Xbox One X Power Supply Replacement, Slide the upper case horizontally: step 3, image 1 of 2 Xbox One X Power Supply Replacement, Slide the upper case horizontally: step 3, image 2 of 2
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
    Ask FixBot
  4. Xbox One X Power Supply Replacement, Lift the upper case off the lower case: step 4, image 1 of 2 Xbox One X Power Supply Replacement, Lift the upper case off the lower case: step 4, image 2 of 2
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
    Ask FixBot
  5. Xbox One X Power Supply Replacement: step 5, image 1 of 3 Xbox One X Power Supply Replacement: step 5, image 2 of 3 Xbox One X Power Supply Replacement: step 5, image 3 of 3
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
    Ask FixBot
  6. Xbox One X Power Supply Replacement: step 6, image 1 of 2 Xbox One X Power Supply Replacement: step 6, image 2 of 2
    • Push the upper plastic case down and away from the console to remove it completely.
    Ask FixBot
  7. Xbox One X Power Supply Replacement, Disconnect the ribbon cable: step 7, image 1 of 3 Xbox One X Power Supply Replacement, Disconnect the ribbon cable: step 7, image 2 of 3 Xbox One X Power Supply Replacement, Disconnect the ribbon cable: step 7, image 3 of 3
    • Use the pointed end of a spudger, an opening tool, or your fingernail to flip down the small, hinged locking flap on the ribbon cable ZIF connector on the front circuit board.
    Ask FixBot
  8. Xbox One X Power Supply Replacement, Disconnect the ribbon cable: step 8, image 1 of 1
    Buy
    • Use blunt tweezers to pull the ribbon cable down out of the connector.
    Ask FixBot
  9. Xbox One X Power Supply Replacement, Remove the front circuit board screws: step 9, image 1 of 1
    • Use a T8 Torx screwdriver to remove the three 13.3 mm screws securing the front circuit board to the upper metal case.
    Ask FixBot
  10. Xbox One X Power Supply Replacement, Remove the front circuit board: step 10, image 1 of 2 Xbox One X Power Supply Replacement, Remove the front circuit board: step 10, image 2 of 2
    • Pull the front circuit board straight out away from the upper metal case and set it aside.
    • Grip the board on either side of where it is plugged in to avoid bending and damaging it.
    Ask FixBot
  11. Xbox One X Power Supply Replacement, Remove the upper metal case screws: step 11, image 1 of 1
    • Use a T10 Torx screwdriver to remove the six 47.7 mm screws securing the upper metal case to the lower plastic case.
    • Use a T8 Torx screwdriver to remove the two 7.5 mm screws securing the press connector to the upper metal case.
    Ask FixBot
  12. Xbox One X Power Supply Replacement, Detach the press connector: step 12, image 1 of 2 Xbox One X Power Supply Replacement, Detach the press connector: step 12, image 2 of 2
    • Insert the flat end of a spudger underneath the press connector on the side opposite of the ribbon cable.
    • Use the spudger to lift the press connector up and away from the upper metal case.
    • Don't push the spudger all the way to the socket. Prying up the socket may damage it.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  13. Xbox One X Power Supply Replacement, Remove the lower plastic case: step 13, image 1 of 3 Xbox One X Power Supply Replacement, Remove the lower plastic case: step 13, image 2 of 3 Xbox One X Power Supply Replacement, Remove the lower plastic case: step 13, image 3 of 3
    • Flip the console over.
    • Hold on to the lower plastic case because it is no longer attached to the metal case.
    • Lift the lower plastic case up from the metal case and set it aside.
    Ask FixBot
  14. Xbox One X Power Supply Replacement, Remove the lower metal case screws: step 14, image 1 of 1
    • Remove the two T10 Torx screws securing the lower metal case:
    • One 7.7 mm screw
    • One 11.4 mm screw
    Ask FixBot
  15. Xbox One X Power Supply Replacement, Remove the lower metal case: step 15, image 1 of 1
    • Lift the lower metal case up off the upper metal case and internal components.
    • The disc drive may lift up with the lower metal case. Hold it down during this step.
    • Set the lower metal case aside.
    Ask FixBot
  16. Xbox One X Power Supply Replacement, Unscrew the power supply and fan: step 16, image 1 of 1
    • The disc drive is only attached to the motherboard by two cable connectors. Hold the disc drive when flipping the console over to avoid damaging it.
    • Use a T10 Torx screwdriver to remove the following screws securing the power supply and fan to the upper metal case:
    • Two 11.4 mm screws
    • One 11.4 mm screw
    Ask FixBot
  17. Xbox One X Power Supply Replacement, Loosen the disc drive: step 17, image 1 of 2 Xbox One X Power Supply Replacement, Loosen the disc drive: step 17, image 2 of 2
    • Lift the disc drive up so that its metal tab is unhooked from the power supply.
    • The disc drive is plugged into the motherboard. Don’t bend the wires more than necessary to avoid damaging them.
    • Place the disc drive on the upper metal case so that it sits over the hard drive. You'll need enough space to unplug the power supply from the motherboard.
    Ask FixBot
  18. Xbox One X Power Supply Replacement, Unstick the foam tape near the power supply: step 18, image 1 of 3 Xbox One X Power Supply Replacement, Unstick the foam tape near the power supply: step 18, image 2 of 3 Xbox One X Power Supply Replacement, Unstick the foam tape near the power supply: step 18, image 3 of 3
    • Insert the flat end of the spudger underneath the dark grey foam tape starting at the corner closest to the power supply and edge of the console.
    • Lift up the corner.
    • Slowly push the spudger through to the other side of the tape until you can see the flat end emerge.
    • Remove the spudger slowly. There are two grey cables underneath the foam tape. Try to avoid hitting them with the spudger so that you don't damage them.
    Ask FixBot
  19. Xbox One X Power Supply Replacement, Move the power supply: step 19, image 1 of 2 Xbox One X Power Supply Replacement, Move the power supply: step 19, image 2 of 2
    • Lift the power supply directly upward to unplug it from the motherboard.
    • Move the disc drive further away from the power supply if you need more space.
    Ask FixBot
  20. Xbox One X Power Supply Replacement: step 20, image 1 of 2 Xbox One X Power Supply Replacement: step 20, image 2 of 2
    • Lift the power supply so that the cables are at a 90 degree angle.
    • Avoid pulling or bending the cables more than necessary to prevent damage.
    Ask FixBot
  21. Xbox One X Power Supply Replacement: step 21, image 1 of 2 Xbox One X Power Supply Replacement: step 21, image 2 of 2
    • While holding the power supply above the console, move the two grey cables out of the plastic hook on the fan case.
    Ask FixBot
  22. Xbox One X Power Supply Replacement: step 22, image 1 of 1
    • Set the power supply on the table.
    Ask FixBot
  23. Xbox One X Power Supply Replacement, Unplug the fan from the motherboard: step 23, image 1 of 2 Xbox One X Power Supply Replacement, Unplug the fan from the motherboard: step 23, image 2 of 2
    • Unplug the bundled cable connector connecting the fan to the motherboard by pulling directly upward.
    Ask FixBot
  24. Xbox One X Power Supply Replacement, Remove the fan: step 24, image 1 of 2 Xbox One X Power Supply Replacement, Remove the fan: step 24, image 2 of 2
    • Lift the fan case up to remove it from the console.
    Ask FixBot
  25. Xbox One X Power Supply Replacement, Remove the power supply socket from the case: step 25, image 1 of 2 Xbox One X Power Supply Replacement, Remove the power supply socket from the case: step 25, image 2 of 2
    • Lift the power supply socket out of the upper metal case.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox One X Answers community for help.
50 other people completed this guide.
Kyle Smith
52,122 Reputation
124 Guides authored
11 Guide Comments
easy to follow
jonathanl27 - Reply Share
Hi all,
Did anyone have any struggles with step 7, disconnecting the ribbon cable? my cable was extremely tight, and take a lot of effort to get the cable out. I’m yet to take delivery of the new power module, but am a little concerned about the ribbon cable being damaged hence the difficulty to get out, or the potential to damage when inserting the ribbon cable back in… any suggestions welcome!
Matthew Chadwick - Reply Share
Hi,
The ribbon cable in step 7 uses a ZIF connector and should be easy to remove from the connector slot. The cable may bend slightly when you pull it out and reinsert it, but avoid bending it as much as possible.
Kyle Smith - Reply Share
Thanks much for this guide - made it super easy to disassemble!
Azarius - Reply Share
An Excellent guide! Thank you very much for the detailed step by step and extra supporting pictures! I'm happy to report that my OneX is back up and running.
AJ Gotch - Reply Share
Past 24 Hours: 34
Past 7 Days: 185
Past 30 Days: 1,009
All Time: 63,396
