(New) iPhone 15 Battery Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. (New) iPhone 15 Battery Installation, Remove the residual battery adhesive: step 1, image 1 of 1
      • If there's any large pieces of residual battery adhesive remaining, use a pair of tweezers to peel them off the iPhone frame.
      • Use coffee filters or a lint‑free cloth and high‑concentration (>90%) isopropyl alcohol to wipe off any remaining battery adhesive residue from the iPhone frame.
      Ask FixBot
    2. (New) iPhone 15 Battery Installation, Remove the plastic sleeve: step 2, image 1 of 2 (New) iPhone 15 Battery Installation, Remove the plastic sleeve: step 2, image 2 of 2
      • If your replacement battery comes with a plastic sleeve, peel it off and remove it.
      Ask FixBot
    3. (New) iPhone 15 Battery Installation, Remove adhesive liner: step 3, image 1 of 2 (New) iPhone 15 Battery Installation, Remove adhesive liner: step 3, image 2 of 2
      • If your battery doesn't come with pre‑installed adhesive, follow this guide to install it, then come back to this guide to finish reassembly.
      • Peel the liner off the battery adhesive.
      Ask FixBot
    4. (New) iPhone 15 Battery Installation, Place the battery: step 4, image 1 of 3 (New) iPhone 15 Battery Installation, Place the battery: step 4, image 2 of 3 (New) iPhone 15 Battery Installation, Place the battery: step 4, image 3 of 3
      • Hold the battery over its place in the iPhone and connect its press connector.
      • With the battery connected, lower it into place and use your fingers to press it into the frame.
      • After the battery is set, use the tip of a spudger to pry up and disconnect the battery cable press connector.
      Ask FixBot
Alex Diaz-Kokaisl
250,021 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 121
