Removing factory feet from a Mac Laptop (Non-Retina)
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: step 1, image 1 of 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: step 1, image 2 of 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: step 2, image 1 of 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: step 2, image 2 of 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: step 2, image 3 of 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: step 3, image 1 of 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: step 3, image 2 of 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: step 3, image 3 of 3
    Tool used on this step:
    iFixit Opening Picks (Set of 6)
    Buy
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: step 4, image 1 of 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: step 4, image 2 of 2
    Adhesive Cleanup Kit (Set of 12)
    Buy
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Finish Line
4 other people completed this guide.
Nick
88,987 Reputation
50 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,468 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 80
All Time: 4,408
