PlayStation 4 Power Supply Replacement
  1. PlayStation 4 Power Supply Replacement, Flip over the PS4: step 1, image 1 of 1
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PlayStation 4 Power Supply Replacement, Remove the warranty stickers: step 2, image 1 of 3 PlayStation 4 Power Supply Replacement, Remove the warranty stickers: step 2, image 2 of 3 PlayStation 4 Power Supply Replacement, Remove the warranty stickers: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PlayStation 4 Power Supply Replacement, Remove the plastic screw covers: step 3, image 1 of 2 PlayStation 4 Power Supply Replacement, Remove the plastic screw covers: step 3, image 2 of 2
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PlayStation 4 Power Supply Replacement, Remove the rear case screws: step 4, image 1 of 2 PlayStation 4 Power Supply Replacement, Remove the rear case screws: step 4, image 2 of 2
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PlayStation 4 Power Supply Replacement, Remove the lower case: step 5, image 1 of 2 PlayStation 4 Power Supply Replacement, Remove the lower case: step 5, image 2 of 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PlayStation 4 Power Supply Replacement: step 6, image 1 of 2 PlayStation 4 Power Supply Replacement: step 6, image 2 of 2
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  7. PlayStation 4 Power Supply Replacement, Remove the power supply unit: step 7, image 1 of 2 PlayStation 4 Power Supply Replacement, Remove the power supply unit: step 7, image 2 of 2
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  8. PlayStation 4 Power Supply Replacement: step 8, image 1 of 3 PlayStation 4 Power Supply Replacement: step 8, image 2 of 3 PlayStation 4 Power Supply Replacement: step 8, image 3 of 3
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
191 other people completed this guide.
Sam Omiotek
73,414 Reputation
288 Guides authored
69 Comments
Gonna do this tomorrow, I'm just hoping this is what's wrong with it.
A few months ago something popped in the system and I smelt a burning scent.
Diamond - Reply
Bro,did it work for you?
I have same problem
EL cablemo -
I have same thing.
Erik Ferguson -
Just be careful when pulling up power supply on the left side facing you when Ps4 is upside-down.
jerrylaird3000 - Reply
Oui c’est exactement ça j’ai arraché un câble.
Est-ce que quand je vais commander le bloc d’alimentation j’aurais j’aurai un autre ?
Fazel Slh -
Past 24 Hours: 61
Past 7 Days: 429
Past 30 Days: 1,819
All Time: 332,515
