This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Удалите следующие винты, крепящие шлейф аккумулятора к материнской плате:
Один 1,7 мм Phillips(крестовой)
Один 1,5 мм Phillips(крестовой)
Используйте пластиковый инструмент, чтобы отключить шлейф аккумулятора от устройства.
Удаляем винты фиксатора шлейфа разъёма док-станции:
Один 1.5 мм Phillips(крестовой) винт
Один 1.2 мм Phillips(крестовой) винт
Удаляем фиксатор шлейфа разъема док-станции.
Удалите маленький кусочек защитной ленты, закрывающий один из винтов.
683 other people completed this guide.
Special thanks to these translators:
91%
Tobias Isakeit is helping us fix the world! Want to contribute?
Start translating ›
37 Comments
When I had changed the dock connector, my iPhone was not able to get a carrier signal. I found an helpful answer in the forum which worked perfectly for me. Make sure you set the correct date and time (after you remove the battery, it will most probably show you 1970) remove the sim card and plug it in again. That worked for me.
I bought the pro tech toolkit and liberation kit and set my work area to the longest one hour of my life. Everything inside the 4s is so tiny and fragile, I was in constant fear of breaking something, but the teardown videos and the comments on this page really help me to get through the entire process.
Thank you everybody and let us continue tinkering our way through all the adversities in this life! Peace!
This guide was perfect! Very detailed and explained everything very well. Only thing I found confusing was step 17, but besides that it went perfectly smooth!
