Student In Progress
This wiki is being worked on by hardworking students.
Documents
Background:
The Samsung WF210ANWXAA is a front-load washing machine designed for household laundry. It has a stainless-steel wash basket and six preset wash cycles for different types of clothing. The washer includes automatic temperature control, a delay-start option, a child lock, and more. It also has a feature that helps reduce noise and movement during high-speed spin cycles. It uses a direct-drive motor and can reach spin speeds of up to 1,100 revolutions per minute. Its front-loading design allows users to wash larger loads while using less water than many traditional machines. The washer is advertised for household users who want energy-efficient cleaning, prefer multiple wash settings, and have limited capacity to stack the machine in a laundry area. Its features were intended to make the washer quieter and easier to install in different areas of a home.
Identification:
This Samsung washer is identified in Samsung's documentation as the WF210ANWXAA model. The device can be identified by its Samsung branding on the top left corner, front-opening loading door, control panel, automatic detergent and softener dispenser, and separate compartments for detergent, fabric softener, and bleach. The control panel includes wash-cycle controls and features including child lock, spin only, clothing color black, and water level. This model could also be recognized by the codes alerted to the users when an error occurs. Such as door unlocked, unbalanced load, and other errors.
Technical Specifications:
  • Model: Samsung WF210ANW/XAA
  • Type: Front-loading washer
  • Height: 38 inches (96.5 cm)
  • Width: 27 inches (68.6 cm)
  • Depth: 31.1 inches (80 cm)
  • Depth with door open 90 degrees: 50.8 inches (129 cm)
  • Weight: 183 pounds (83 kg)
  • Water pressure: 20–116 psi (137–800 kPa)
  • Power supply: 120 volts
  • Heater rating: 900 watts
  • Spin speed: 1,100 revolutions per minute
  • Power consumption—washing: 140 watts
  • Power consumption—washing and heating: 960 watts
  • Power consumption—spin: 430 watts
  • Power consumption—drain: 80 watts
Additional Information:
Janet Bailey
16 Reputation
0 Guides authored
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 131
All Time: 2,725
