Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The ROG Strix G16 Gaming Laptop (G614J) was released in 2023 and is a part of the Strix gaming laptop series. It is powered by a Core-i7 13650 HX processor with 14 cores, and an RTX 4050. It supports up to 32GB of DDR4 memory and has a 16-inch display. It also has RGB customization and a Tri-fan Cooling system with an addition of Liquid Metal Cooling. The device is available in multiple regions and is targeted at gamers and professionals who need high-performance computing capabilities for things such as gaming, video editing, and intense multitasking. At launch, the laptop was priced at $1,999 USD although prices vary based on the technical specifications and regional differences. The device is the successor to the previous G15 model and was succeeded by the 2024 model, which offered faster CPU, more memory and storage options, and improved graphics.
Identification
The ROG Strix G16 Gaming Laptop (2023) G61, approximate dimensions of 13.94 inches W x 10.39 inches D x 0.89 inches H and weighing 5.51 pounds. It often comes in a Eclipse Gray color with an ROG symbol on the back of the screen. Its designed with a thick base featuring diagonal air circulation vents running through the base of the 16-inch laptop screen with approximate 1/4 of an inch gap between the base and screen. On the bottom left corner of the laptops keyboard, you will find technical stickers for GPU and CPU components. On the base of the laptop, there will be a sticker with a serial number and the device name. The keyboard features RGB per-key.
Technical Specifications
Operating System
  • Windows 11 Pro
Processor
  • 13th Gen Intel Core i7-13650HX
  • 2.6 GHz 24M Cache, up to 4.9
  • Cores: GHz, 14 cores: 6 P-cores and 8 E-cores
Graphics
  • GPU: NVIDIA GeForce RTX 4050 (194 AI TOPs)
  • ROG Boost: 2420 MHz at 140W (2370MHz)
  • Dynamic Boost: Boost Clock+50MHz OC, 115W+25W
  • 6GB GDDR6
Display
  • Size: 16-inch
  • FDH+ 16:10 (1920 x 1200, WUXGA)
  • IPS-level
  • Screen: Anti-glare Display
  • sRGB: 100%
  • Refresh Rate: 165Hz
  • Response Time: 7ms
  • G-sync
  • Support Dolby Vision HDR: Yes
Memory
  • 16GB DDR4-4800 SO-DIMM x2
  • Max Capacity: 32GB
  • Support dual channel memory
Storage
  • 512GB PCIe 4.0 NVMe M.2 SSD
Expansion Slots (Includes Used)
  • 2x DDR5 S0-DIMM slots
  • 2x M.2 PCIe
Cooling
  • Vents: Full-Surround
  • Heatsink: Full-width (374 heatsink fins)
  • Tri-Fan Technology
  • Thermal Paste: Conductonaut Extreme Liquid Metal
  • 7 Heatpipes
  • OdB Ambient Cooling
  • Dust Filter
  • 0.1mm Ultra Thin Fin
  • CoolZone Keyboard
Keyboard and Touchpad
  • Backlit Chiclet Keyboard Per-Key RGB
  • Touchpad
Camera
  • 720P HD Camera
I/O Ports
  • 1x 3.5mm Combo Audio Jack
  • 1x HDMI 2.1 FRL
  • 2x USB 3.2 Gen 2 Type-A (data speed up to 10Gbps)
  • 1x USB 3.2 Gen 2 Type-C with support for DisplayPort™ / power delivery / G-SYNC (data speed up to 10Gbps)
  • 1x RJ45 LAN port
  • 1x Thunderbolt™ 4 with support for DisplayPort™ (data speed up to 40Gbps)
Audio
  • Smart Amp Technology
  • Dolby Atmos
  • AI noise-canceling technology
  • Hi-Res certification (for headphone)
  • Support Microsoft Cortana near field/far field
  • Built-in array microphone
  • 2-speaker system with Smart Amplifier Technology
Network and Communication
  • Wi-Fi 6E(802.11ax) (Triple band) 2*2 + Bluetooth® 5.3 Wireless Card (*Bluetooth® version may change with OS version different.)
Battery
  • 90WHrs, 4S1P, 4-cell Li-ion
Power Supply
  • ø6.0, 280W AC Adapter, Output: 20V DC, 14A, 280W, Input: 100~240C AC 50/60Hz universal
Other
  • Aura Sync: Yes
  • Device Lighting: Aura Sync Light Bar
  • Weight: 2.50 Kg (5.51 lbs)
  • Dimensions (W X D X H): 35.4 x 26.4 x 2.26 ~ 3.04 cm (13.94" x 10.39" x 0.89" ~ 1.20")
  • Microsoft Office: 1-month trial for new Microsoft 365 customers. Credit card required.
  • Ecolabels & Compliances: ENERGY STAR
Security
  • BIOS Administrator Password and User Password Protection
  • Trusted Platform Module (Firmware TPM)
  • McAfee® 30 days free trial
Source: ROG Strix G16 Gaming Laptop (2023) G614
Additional Information
Previously asked user forum
  • A reddit forum that focuses on upgrading the RAM and SSD of the laptop.
How to Replace/Upgrade SSD Storage
  • A Youtube video showing how to replace or upgrade the SSD Storage.
Disassembly, Upgrade options, and Maintenance
  • A webpage that shows how to disassemble, upgrade, and maintain your laptop. It also has a Youtube video that you can follow along to.
Repair Manuals and Support Sources
Asus User Repair Manual
  • An official repair manual from ASUS for the ROG STRIX gaming notebook PC series.
Asus Service Manual
  • An official service manual from ASUS for the ROG STRIX gaming notebook PC series.
ROG STRIX G16 (2023) Review
  • A review that showcases the differences in the ROG STRIX G16 models as well as the technical specifications of the laptop.
Artem Ivat
3,948 Reputation
13 Guides authored
Kid fixers Member of Kid fixers
Community
227 Members
2,118 Guides authored
Past 24 Hours: 18
Past 7 Days: 105
Past 30 Days: 531
All Time: 10,581
