ROG Strix G16 (G614J) M.2 SSD Replacement
  1. ROG Strix G16 (G614J) M.2 SSD Replacement, Remote the Backplate Screws: step 1, image 1 of 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Remote the Backplate Screws: step 1, image 2 of 2
    • Remove the following screws
    • PH0 Screws
    • This one remains captive to the backplate and will not come off.
    • These ones are also PH0 but are longer then the other ones.
  2. ROG Strix G16 (G614J) M.2 SSD Replacement, Opening: step 2, image 1 of 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Opening: step 2, image 2 of 2
    • Slide an Opening Pick around the edge until you make an opening
    • Carfully lift the backplate with your hand
  3. ROG Strix G16 (G614J) M.2 SSD Replacement, Locating Slots: step 3, image 1 of 1
    • There are 2 slots labeled "SSD1" and "SSD2"
    • The SSD1 slot has a preinstalled SSD by the OEM and has your operating system on it
    • The SSD2 slot is free and you can install a M-Key M.2
  4. ROG Strix G16 (G614J) M.2 SSD Replacement, Removing tape: step 4, image 1 of 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Removing tape: step 4, image 2 of 2
    • Lift/Remove the tape to reveal the slot
    • You may decide if you would like to keep the tape, we will be reapplying it in step 9
  5. ROG Strix G16 (G614J) M.2 SSD Replacement, M.2 Screw: step 5, image 1 of 1
    • Remove the PH00 Screw.
  6. ROG Strix G16 (G614J) M.2 SSD Replacement, Inserting the M.2: step 6, image 1 of 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Inserting the M.2: step 6, image 2 of 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Inserting the M.2: step 6, image 3 of 3
    • Carfully slide in the M.2 into the slot
    • Make sure to align the pins properly to avoid damaging them
    • Make sure you are installing a M-Key (5pin) M.2, A B-Key or a B&M-Key is not supported
  7. ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 1/2: step 7, image 1 of 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 1/2: step 7, image 2 of 2
    • Press down on the M.2
  8. ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 2/2: step 8, image 1 of 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 2/2: step 8, image 2 of 3 ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing In 2/2: step 8, image 3 of 3
    • Align the M.2 with the screwdriver hole
    • Screw in the M.2
  9. ROG Strix G16 (G614J) M.2 SSD Replacement, Reapplying the Tape: step 9, image 1 of 2 ROG Strix G16 (G614J) M.2 SSD Replacement, Reapplying the Tape: step 9, image 2 of 2
    • Reapply the tape
    • If you have removed the tape and you dont want to reapply it you may skip this step
  10. ROG Strix G16 (G614J) M.2 SSD Replacement, Reinstalling the backplate: step 10, image 1 of 1
    • Align the backplate and firmly press down on the edges
  11. ROG Strix G16 (G614J) M.2 SSD Replacement, Screwing in: step 11, image 1 of 1
    • Screw in all the PH0 Screws
    • Short Screws
    • Long Screws
    • Captive Screw
Enjoy!
8 other people completed this guide.
Artem Ivat
3,678 Reputation
13 Guides authored
Kid fixers Member of Kid fixers
Community
208 Members
291 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 57
Past 30 Days: 334
All Time: 5,386
