Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
The Joy‑Con 2 grip allows you to use Joy‑Con 2 controllers in a more traditional controller layout. The grip has 4 rubber caps, two on each side, allowing balance with HD rumble 2. It also has two feet on the bottom of the grip to make it easy to put on display or stand it up.
The Joy‑Con 2 charging grip uses magnets to secure the controllers, the exact same ones as the Switch 2 body. Two magnets are hidden with colorful stickers on each side, attracting the steel SL and SR buttons on each controller.
Identification
The original Joy‑Con grip is very similar to the, but the original has the Switch 2 logo on it, and it is unable to charge the controllers while connected. It has model number BEE-009 engraved under the grip.
redratchet21
3,012 Reputation
12 Guides authored
Kid fixers Member of Kid fixers
Community
227 Members
2,172 Guides authored
Past 24 Hours: 1
Past 7 Days: 35
Past 30 Days: 154
All Time: 1,032
