Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Microsoft Bluetooth Ergonomic Mouse was designed to provide comfort and reduce strain during extended usage. Its curved shape and built-in thumb support allow users to have a more natural hand position, making it a popular choice for office/everyday work.
This mouse connects wirelessly using Bluetooth, allowing for an easy and organized setup and compatibility with nearly all modern devices. It is powered by replaceable AAA batteries and is intended for general use rather than high-performance use.
Identification
The Microsoft Bluetooth Ergonomic Mouse can be identified by its curved, right-handed design and smooth outer shell. It also has a Microsoft logo on the top and a scroll wheel between the left and right buttons.
On the bottom of the mouse, there is a power switch, a Bluetooth pairing button, and a removable battery cover. The model name and other identifying information may also be found inside the battery compartment.
Technical Specifications
  • Bluetooth connectivity (no USB receiver)
  • Powered by 2 AAA batteries
  • Compatible with Windows 10/11
  • Ergonomic right-handed design
  • Standard left/right click and scroll wheel
  • Wireless range up to ~30 feet
Sources:
Additional Information
Author
with
Tristan Boyer
177 Reputation
1 Guide authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 90
All Time: 549
