Guides
Ask a Question
There are no questions. Be the first to ask a question!
Background
The RS Shifter & Handbrake is a sim-racing peripheral pair designed to add realistic gear and handbrake control to racing rigs. Key features include an H-pattern shifter and a progressive handbrake with adjustable mounting for rigs and desks. The assemblies use durable metal components and ABS plastic housings intended for long-term use under repeated mechanical stress. Logitech's support page lists limited software resources for this product and no downloadable firmware or spare parts.
Identification
The Logitech RS Shifter & Handbrake can be identified by the model number (M/N WU0018). The model label is on the underside of each unit's base or on the mounting surface. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: External sim-racing accessories (separate shifter and handbrake units)
  • Shifter Type: 6-speed H-pattern with optional sequential actuation (H-pattern gate)
  • Handbrake Type: Progressive analog handbrake (potentiometer-based lever with spring return)
  • Connectivity: Wired USB connection (to wheel base or PC via wheel harness)
  • Materials: Metal internal components and mounting clamp, ABS plastic housing
  • Switches / Sensors: Proprietary micro-switches and analog potentiometer (manufacturer/model not specified on Logitech support page)
  • Mounting: Adjustable clamp and bolt mounting for desks and rigs; compatible with standard sim rig layouts
  • Compatibility: Designed for use with Logitech racing wheels and PC; confirm compatibility with your wheel model
  • Spare Parts: No spare parts listed on Logitech support page
  • Software / Firmware: No downloads or firmware updates available on Logitech support page
Troubleshooting
Common faults include unresponsive switch contacts, worn potentiometer on the handbrake, damaged USB/cable connections, and loose or broken mounting hardware. Diagnose by checking USB continuity, measuring potentiometer resistance across travel with a multimeter, inspecting and actuating individual switches, and verifying clamp integrity. Logitech's support page indicates no spare parts or downloads for this product, so repairs typically involve component-level servicing or replacement of the whole unit.
For additional troubleshooting help, visit: Visit Logitech Support (https://support.logi.com) and the product FAQ page for contact options; note the product support page lists no downloads or spare parts.
Additional Information
Warranty Info
Refer to Logitech's warranty page for region-specific limited hardware warranty terms; coverage varies by region.
Tim Asp
42,386 Reputation
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 45
All Time: 462
