Logitech RS Shifter Handbrake Top Cover Replacement
    1. Logitech RS Shifter Handbrake Top Cover Replacement, Before you begin: step 1, image 1 of 3 Logitech RS Shifter Handbrake Top Cover Replacement, Before you begin: step 1, image 2 of 3 Logitech RS Shifter Handbrake Top Cover Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin your repair:
      • Unplug the shifter's USB cable.
      • Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
      • Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
      Ask FixBot
    1. Logitech RS Shifter Handbrake Top Cover Replacement, Remove the handle: step 2, image 1 of 3 Logitech RS Shifter Handbrake Top Cover Replacement, Remove the handle: step 2, image 2 of 3 Logitech RS Shifter Handbrake Top Cover Replacement, Remove the handle: step 2, image 3 of 3
      • Twist the handle counterclockwise to unscrew and remove it.
      • Grip the knurled section of the handle, not the collar at the base.
      Ask FixBot
    1. Logitech RS Shifter Handbrake Top Cover Replacement, Remove the top cover: step 3, image 1 of 2 Logitech RS Shifter Handbrake Top Cover Replacement, Remove the top cover: step 3, image 2 of 2
      • Use a 2.5 mm hex screwdriver to remove the four 11 mm‑long screws securing the top cover.
      Ask FixBot
    2. Logitech RS Shifter Handbrake Top Cover Replacement: step 4, image 1 of 2 Logitech RS Shifter Handbrake Top Cover Replacement: step 4, image 2 of 2
      • Lift the top cover straight up to remove it—the metal shift gate is sitting loosely in the cover.
      Ask FixBot
Spencer Day
197,893 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 58
