Guides
Documents
Models
A00130
Background
The G Pro X wireless headset was launched as part of Logitech's G series line, alongside the wired version. This gaming headset comes equipped with Logitech's Blue Vo!ce broadcast filers, surround sound, Pro-G 50 mm drivers, and Lightspeed wireless technology. The G Pro X wireless headset is made of steel and aluminum and has memory foam ear pads.
Identification
The G Pro X wireless headset has oval-shaped ear cups with the Logitech logo etched in metal on the outside. The top of the headband has "Pro" written in the leatherette. This headset has a power button, volume scroll wheel, USB-C port, mute button, and microphone jack on the left cup. The wired version looks almost identical, but only has two jacks on the bottom. It has two color options—black or "Shroud" with blue accent. You can find the part number (P/N) and model number (M/N) by removing the right ear pad and looking on the ear cup. The black G Pro X wireless headset has model number A00130 and part number 981-000906. The Shroud edition has part number 981-000956.
Technical Specifications
Dimensions
  • Length: 5.43 in (138 mm)
  • Width: 3.70 in (94 mm)
  • Height: 7.68 in (195 mm)
  • Weight: 13.05 oz (370 g)
  • Charging cable length: 5.9 ft (1.8 m)
Headphone
  • Driver: Hybrid mesh PRO-G 1.97 in (50 mm)
  • Magnet: Neodymium
  • Frequency response: 20 Hz - 20 kHz
  • Impedance: 32 Ohms
  • Sensitivity: 91.7 dB SPL @ 1 mW & 1 cm
Materials
  • Fork: Aluminum
  • Headband: Steel
  • Ear and head pads: Memory foam leatherette
  • Extra ear pads: Memory foam cloth
Microphone
  • Pickup pattern: Cardioid (unidirectional)
  • Type: Electret condenser
  • Size: 0.24 in (6 mm)
  • Frequency response: 100 Hz - 10 KHz
Wireless
  • Battery life (rechargeable): Up to 20h
  • Wireless range: Up to 49.22 ft (15 m)
  • Connection type: 2.4 GHz Lightspeed
Compatibility
  • PC with USB port
  • Windows 7 or later
Additional Information
Milan Joaquin
377 Reputation
1 Guide authored
Past 24 Hours: 12
Past 7 Days: 95
Past 30 Days: 366
All Time: 8,372
