GameSir X5 Lite Trigger Replacement
    1. GameSir X5 Lite Trigger Replacement, Trigger: step 1, image 1 of 3 GameSir X5 Lite Trigger Replacement, Trigger: step 1, image 2 of 3 GameSir X5 Lite Trigger Replacement, Trigger: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four 8 mm screws located on the back cover.
      Ask FixBot
    2. GameSir X5 Lite Trigger Replacement: step 2, image 1 of 1
      • Fully extend the controller and remove the six 5 mm Phillips #00 screws off the back of the extender.
      Ask FixBot
    3. GameSir X5 Lite Trigger Replacement: step 3, image 1 of 1
      • Use an opening pick to loosen the back cover to reach the end of the extender.
      Ask FixBot
    4. GameSir X5 Lite Trigger Replacement: step 4, image 1 of 2 GameSir X5 Lite Trigger Replacement: step 4, image 2 of 2
      • Pull the extender to reach the last two 5 mm screws.
      • Unscrew the two 5 mm Phillips #00 screws.
      • Remove the springs to separate the two sides of the controller by unscrewing the two 5 mm Phillis #00 screws.
      Ask FixBot
    5. GameSir X5 Lite Trigger Replacement: step 5, image 1 of 1
      • Loosen the three 7 mm Phillips #00 screws where the triggers are located and remove one 7 mm Phillips #00 screw that sits below the joystick.
      • The three 7 mm screws where the triggers are located will not be removed, only loosened.
      Ask FixBot
    6. GameSir X5 Lite Trigger Replacement: step 6, image 1 of 1
      • Lift and remove the panel to access the trigger.
      Ask FixBot
    7. GameSir X5 Lite Trigger Replacement: step 7, image 1 of 1
      • Gently lift the trigger upwards at either end to remove it from the panel.
      • Grab a new trigger and connect it by ensuring it clicks onto both connecting points.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 146
All Time: 301
